Old 06-21-2008, 07:41 AM
Zippster's Avatar
Zippster Zippster is offline
Dedicated Server
I know this has to have been asked multiple times somewhere, I searched and cant seem to find it.
I have a computer that will be dedicated Sage server only and feed my new HD100 and future add ons.
Which software do I install on the server? The whole Sage Tv software with license or is their a dedicated server software? Server is running XP Pro.
Old 06-21-2008, 08:09 AM
othy othy is offline
Install the "regular" SageTV Media Center. It can act either as a server or a "standalone" solution. Your regular license will work.
There is a separate program for a client, but obviously you wouldn't need that if you'll use an HD100.
Tim
Server: WHS, Phenom 9150e Quad-Core, 2.0TB for recordings (pooled). HD-PVR (w/USB-UIRT), HDHR, ATI550.
Clients: HD200 (wired), HD100 (wireless via Netgear WNHDEB111).
Old 06-22-2008, 08:00 AM
Djc208's Avatar
Djc208 Djc208 is offline
Tim
I'd also recommend setting it up to run as a service. This will automatically enable it upon startup and prevent most people from shutting it down by accident if the computer is used for normal stuff too. It also saves resources by not running the user interface on the server. You can still run the interface if you use the server for playback but otherwise there's no point.
There's an option during setup to open the service manager which will let you enable it. You can also allow it to auto-restart if it should crash and set up the user if you use multiple log-ins with different permissions.
Old 06-22-2008, 08:32 AM
Zippster's Avatar
Thanks guys, I looked into the service and definitely will use that as this box will be dedicated to sage ( server, NO client ) only.
Guess I should also look into setting up a user for Sage to run under with less priviledges, off hand anyone have a list of what permissions the Sage user should have and not?
Old 06-22-2008, 09:12 AM
You will be much better off with a user with Administrator privileges when using service mode. Also that user must have a password to access UNC paths.
Old 06-23-2008, 07:42 AM
Djc208's Avatar
I have mine set up as the only account with admin privileges. Used the password tools to have it auto-login on bootup. That way I can remote access the server from my network to take care of updates/changes etc. since I don't have a monitor connected.
Ubuntu Hardy (8.04) - Client RazorJack SageTV Linux 4 05-02-2008 08:17 PM
SageTV Client lockups and associated server side error Surtr SageTV Software 1 05-28-2007 06:55 AM
Architecture - Dual Server or Server/Client ? Berg Hardware Support 3 08-17-2006 05:58 PM
help... Placeshifter does not like new server... spect_tv SageTV Placeshifter 2 07-11-2006 11:41 PM
SageTV 4.1 is crashing Win2003 server SethV SageTV Software 7 02-03-2006 11:16 PM
