Old 02-07-2004, 09:54 PM
KeDruff KeDruff is offline
Send a message via AIM to KeDruff
Scanning/Scrolling
Guys --
I've got beta 2.0.12 and am impressed so far. However, I can't figure out how to go to a specific point in the playback file. (Whether it's "live" or from my library, etc.) How do I select a specific point in a show. In other words, if I'm at the end of the show and want to go back to the beginning how do I do this short fo rewinding through the whole show?
Kevin
Old 02-07-2004, 09:57 PM
fidget's Avatar
fidget fidget is offline
Re: Scanning/Scrolling
Originally posted by KeDruff
Guys --
Kevin
The easy way, as far as I can tell is to watch another program and then come back to this one. Since you have completed the program, it will restart from the beginning. Another way is to use the "Time Scroll" feature, but that will only allow you to jump by 2.5 minutes at a time. Unfortunately, this means that you will indeed be rewinding through the show, just a bit faster.
