Old 08-14-2008, 11:00 AM
trueno trueno is offline
Uninstall stvi?
How do you uninstall/unimport an stvi after importing it?
Thanks..
Old 08-14-2008, 11:22 AM
matt91's Avatar
matt91 matt91 is offline
just revert back to the prior SageTV3.xml file.
Old 08-14-2008, 07:00 PM
thecgmguy thecgmguy is offline
So I guess that means we should be backup the xml file prior to importing new STVis?
Old 08-14-2008, 07:29 PM
MeInMaui's Avatar
MeInMaui MeInMaui is offline
That isn't necessary. When an STVi is imported, it creates a new instance of the STV first and appends/increments a number on the end of the file name. After installation of one import, SageTV3.xml would become SageTV3-1.xml and the original file is left untouched.
Aloha,
Mike
- Nikolaus (4yrs old)
Old 08-14-2008, 08:23 PM
If you use the default STV in v6.4, just use the new STVI plugin manager -- if you remove an import from the list, it will just rebuild using the imports still in the list.
As usual, the base STV file doesn't get changed.
Is there an easy way to generate an stvi? stuckless SageTV Studio 2 10-09-2007 09:17 AM
SageTV won't uninstall...also I have no uninstall file. Mtlca401 SageTV Software 1 11-29-2006 05:48 PM
Translate STVi owilsky SageTV Studio 10 10-21-2006 07:46 AM
Uninstall Mpeg Decoders doublebogey SageTV Software 3 10-02-2006 10:03 AM
Uninstall Plugins? mightyt SageTV Customizations 11 03-09-2006 06:35 AM
