I have an HD PVR which I'm trying to use with SageTV Client. When I try to watch Live TV, I get this message:
There was a Playback Error in playback. Details:The same thing happens if I try to play a show recorded by the PVR and SageTV on the client. This error also occurs if I test video playback in the video configuration wizard on the client. I searched the forum and FAQ and found I need to have a video decoder installed. I first tried installing PowerDVD 6, but that didn't work (it doesn't have an H.264 decoder.) So I plugged the HD PVR into the client computer (the installer wouldn't work without the PVR connected) and installed the Hauppauge driver and Arcsoft software from the CD. If I understand correctly, this has installed the Arcsoft H.264 encoder/decoder on this computer. I also entered these settings into the Properties file on the client: videoframe/aac_audio_decoder_filter=ArcSoft Audio Decoder HDDetailed Setup->Video/Audio->H264 Video Decoder now shows ArcSoft Video Decoder. However, the SageTV Client still gives the same error message when trying to play live TV, play a recording, or perform the video playback test. FWIW, Arcsoft Media Theater on the client computer plays the PVR's recordings fine, so it appears that the Arcsoft video decoder has been installed. What am I doing wrong?
Server: Gigabyte GA-EP45-UD3R, Intel E7400, 2GB, MSI 8800GT 512 OC, XP Pro SP3 Client 1: BioStar TP45HP, Intel Q9650, 6GB, MSI N250GTS, Win7 HP 64; Client 2: GIGABYTE GA-970A-UD3, Phenom II X3 720 2.80 GHz, 8 GB, EVGA GTX650Ti, Win7 HP 64; Client 3: Acer Aspire 7552, Phenom II N950 Quad 2.10 GHz, 8 GB, ATI Mobility Radeon HD 5650, Win7 HP 64 Tuner: Hauppauge HD PVR Rev E3 Receiver: Explorer 4250HDC |
Wait. I just found the fddshow H.264 decoder, installed it, and it seems to be working.
You should be able to make all the decoder selections in the GUI with the latest versions of Sage. Do you see Arcsoft as an option in Sage? If not you did not get TME installed correctly.
I also should say that although fddshow works, SageTVClient crashes quite often since I started using fddshow. Sometimes it crashes while I'm navigating STVC's menus, sometimes it crashes when STV is transitioning from one live TV show to another at the end of an hour, and sometimes (fairly often) it crashes while I'm just watching something, either live or a recording. I'd say on average it crashes about 4 or 5 times per hour while watching. So it looks like fddshow is not a very good solution, at least on my system. I'd love to get the Arcsoft decoder working. It works fine on my SageTV server.
Voila! I uninstalled SageTVClient, rebooted, and reinstalled it. Now the Arcsoft decoder appears in STVC's video setup for an H.264 decoding option. I simply selected it, and now the Client is working much better. Only one crash so far, and it was different than those I was getting with fddshow: STVC hung (froze) rather than simply crashing to the desktop. Hopefully that kind of failure will be rare.
Thanks, SWKerr and darcilicious!
Using HD-PVR, WHS, and SageTV Client | Beefcake550 | SageTV Software | 2 | 08-14-2008 01:16 PM |
SageTV Mac beta and myTV.PVR/WinTV PVR USB2 users | iconic | SageTV Beta Test Software | 2 | 12-18-2007 05:00 PM |
PVR-350 Output and SageTV Client | dvsing | SageTV Beta Test Software | 5 | 01-29-2004 07:45 PM |
WinTV-PVR USB2 and SageTV Client | spud | Hardware Support | 2 | 11-05-2003 09:26 AM |
PVR-350 output in SageTV client? | mlar | SageTV Beta Test Software | 2 | 05-25-2003 04:46 PM |
