Old 12-17-2009, 07:44 PM
jdamore jdamore is offline
Great 23" 1080p monitor for the HD200
Found a great 23" 1080p monitor to use with the HD200 only $139.99..
http://www.bestbuy.com/site/Hannspre...pree&cp=1&lp=1
HDMI input, integrated speakers, wall mountable..
The only caveat is theres no remote to power it on/off. Maybe ill pick up one of those remote power switches like what you use to turn the christmas lights on and off (im sure they will go on sale after x-mas )
Happy Holidays Folks!
Old 12-17-2009, 08:03 PM
CollinR CollinR is offline
http://www.bestbuy.com/site/Dynex%26...&skuId=9427649
I got one of these not too long ago, not bad but no discrete codes that I know of.
Old 12-18-2009, 06:22 AM
While I can't verify about the Hannspree LCD monitor, I have an ASUS 21.5" 1080P monitor hooked up to the HD200, if I use a DVI to HDMI cable to hook them up, then the Monitor will automatically go to sleep when you power down the HD200. Hooked up HDMI to HDMI requires you to power off the monitor manually.
I did not figure this out, so I am only passing it on and not taking credit for it!
Old 12-18-2009, 03:05 PM
valnar valnar is offline
Dynex and Hannspree?
Remember, you get what you pay for.
Client 2: HD300 on Vizio 40"
Old 12-19-2009, 12:02 PM
freedml freedml is offline
Sometimes the off-brand stuff is just fine and a good value, sometimes the brand-name stuff is expensive and not worth it. If this stuff lasts 30 days it will probably last 3 years which makes it a decent value. You don't only "get what you pay for".
HD200 support for 1080p/24 HeadHodge SageTV Beta Test Software 15 07-16-2010 08:38 AM
"OpenPandora"... A great music addon for SageTV! mkanet SageTV Customizations 2 12-04-2006 09:13 PM
Enabling "1080p" AWS Hardware Support 8 05-02-2006 02:54 AM
Anyone know the Video/Audio encoding setting behind "Great 3GB per hour" etc? jwalloga SageTV Software 7 02-10-2005 03:46 PM
