Old 01-31-2010, 10:31 PM
OldPCGUY's Avatar
OldPCGUY OldPCGUY is offline
How do I increase Java Heap Size
I am total lost. I got a Java Heap size error but I have 4G of memory running XP Windows.
I searched a bunch of posts on Java heap size but none of them tells you how or where to increase.
I don't know if I should increase Java Heap Size in Sage(through some menu) or Sage.properties or is it a Windows System option.
Any help would be greatly appreciated.
SERVER/Endcoder: ASUS M2NE,AMD 5600, 4G Ram, ATI 3850, 10 TB, Antec P180 Case
OS/Software: Win XP SP3 (32bit), Smart Defrag, Care, Windows Defender, Sage 7.1.5
Encoders ATSC: HVR 1800 (PCIE), HVR2250(PCIE)
Satelite: Dish VIP622 Bronze HD Pacakge, HD PVR Rev E1 1.5.6.1
TV1: Vizio 42" LCD 1080P 60HZ, Sage HD200, Yamaha 6.1
TV2: Samsung 26" LCD720P 60HZ, Sage HD200, TV Sound
Network: Airlink 300N to DLINK DAP-1522 to Sage HD200
Old 01-31-2010, 10:56 PM
HelenWeathers's Avatar
click start
click run
type regedit and click ok
expand HKEY_LOCAL_MACHINE
expand SOFTWARE
expand Frey Technologies
under SageTV in right window doubleclick on JVMMaxHeapSizeMB
set as follows
100h=256
200h=512
300h=768
400h=1024
400h is probably best, especially w 4gb of memory
Old 01-31-2010, 11:02 PM
OldPCGUY's Avatar
Great Helen Responds Again!!!!
You are one of the best persons on this forumn!!
Easy to set with the instructions you gave me!!
It was set to 000H so I have no idea how it ever worked.
Old 01-31-2010, 11:12 PM
I think there should probably be a comma after Great.
I think when not set it defaults to 100h (256d).
Old 02-01-2010, 08:52 AM
matt91's Avatar
matt91 matt91 is offline
there is also a little applet that will do this automagically for you.
It's posted on here someplace.
Old 02-01-2010, 09:01 AM
JetreL's Avatar
JetreL JetreL is offline
Here is the link to the tool.
Link
I have used it once. Seems to work fine, though I really don't mind doing the manual edits as needed. This at least keeps them all in the same place.
Old 11-24-2010, 02:38 PM
Chriscic Chriscic is offline
Originally Posted by HelenWeathers View Post
click start
click run
expand SOFTWARE
set as follows
100h=256
200h=512
300h=768
400h=1024
Sorry for being dense, but am I typing in "300h" or that shorthand for typing in "300" in hexidecimal mode? Guessing the latter. Thanks.
Old 11-24-2010, 03:21 PM
Yes, you just enter 300 (and leave off the h).
Old 04-14-2011, 11:02 PM
traker1001 traker1001 is offline
Wrong thread
Old 04-19-2011, 12:06 PM
aweber1nj aweber1nj is offline
Is there a similar setting that should be tweaked on Sage Client 7.1.5 (Win7)?
I found the HKLM setting listed above on the STV Server, and changed it, but if I'm running Diamond, etc., on the client, is there a similar key that needs to be increased, or is it located elsewhere in the client settings?
AJ
Old 04-19-2011, 01:22 PM
AJ
its the same key on the client (obviously change the key on the client, it does not inherit the key from the server)
Check out TVExplorer
Old 04-19-2011, 01:55 PM
Tomahawk51's Avatar
Tomahawk51 Tomahawk51 is offline
click start
click run
expand SOFTWARE
set as follows
100h=256
200h=512
300h=768
400h=1024
I (will soon) have 6gb of RAM. Any reason to go with MORE than 1024? Can I even do that? I recall someone says Java can only go to 1.5gb (of contiguous RAM), but I don't recall ever seeing advice on this. Is going with more OK or a bad idea?
Old 04-19-2011, 02:18 PM
panteragstk's Avatar
Mine is set to 13**MB on one client and 1100MB on another. The one with 1100 gets close to full quite often.
Old 04-19-2011, 04:58 PM
OK, but neither the key nor the value (even the default of 0) exists on the client. So just create it, and it will use it?
Old 04-19-2011, 05:00 PM
Forgive me, but having done a fair share of java development, that's a pretty obscene amount of memory. Do you still get OOM exceptions occasionally, or is this just purely that you're running every plug-in known to man?
Old 04-19-2011, 05:18 PM
If the client is 64bit look here:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Frey Technologies\SageTV
Also if you are using vista/Win7 and have UAC enabled then the actual key you need to modify exists in the virtual store... changing the one you think you need to doesn't actually do anything. See this post for some more details
Old 04-19-2011, 06:30 PM
Yeah, I disabled UAC on one of the two machines...maybe that's the one I didn't do yet. I'll check that in the morning. Thanks for the tip on that.
BTW: One of the reasons I'm bumping the heap is so I can install TVExplorer!!! (I'm sure you have it tested on 7.1.5 by now, right?)
Old 04-19-2011, 06:56 PM
yup works just peachy on 7.1.5
Old 04-20-2011, 08:24 AM
Not too many plugins, but some of them (especially the beta ones) use lots of heap (image caching I think). I don't get any OOM errors any more, but those were caused by a known problem with diamond.
Old 10-31-2011, 12:32 AM
wildgoose wildgoose is offline
On Win7 64bit, the key is here:
HKEY_CURRENT_USER\Software\Classes\VirtualStore\MACHINE\SOFTWARE\Wow6432Node\Frey Technologies\SageTV\
Default:
JVMMaxHeapSizeMB = 0
Setting this to 400 (1024) works correctly in my Sage v7.
Java Heap Size rickgillyon SageTV Beta Test Software 48 12-14-2011 04:47 AM
Java Heap Size craigap SageTV Media Extender 21 03-27-2010 10:53 AM
How do I increase Java Heap Size in OS X? merneric SageTV Mac Edition 15 11-10-2009 04:36 PM
HD-PVR lockup related to Java heap size? troll5501 Hardware Support 14 11-04-2009 02:03 PM
Java Heap Size issue in SageMC on imported MCE (dvr-ms) recordings 71_Cuda SageMC Custom Interface 15 03-28-2009 08:54 AM
