Old 09-01-2010, 03:53 AM
radiopaque's Avatar
radiopaque radiopaque is offline
SCART RGB through breakout cable on the new 300?
Hi,
Will I be able to simply use a converter cable to get a SCART output, or does the 300 not do RGB? This latter bit is important, as one of my TV's can only understand RGB SCART, no other types and no digital at all, either!
Mark
CQC home automation and SageTV Server on Dell PE840 with 6TB RAID5 and two hauppauge tuners ; UPC cable TV ; Secondary headless unRAID on old Pentium 4 system with 3.8TB storage ; SageTV and AnyDVD on HTPC ; Arcam FMJ AV9 and P7, Anthony Gallo Reference AV speakers L/R/C and Gallo spheres for surround ; 50" Panasonic Plasma ; SB players throughout the house.
Old 09-01-2010, 12:01 PM
GKusnick's Avatar
GKusnick GKusnick is offline
As far as I know, the only outputs available through the breakout cable are component video, composite video, and analog stereo audio. There is no S-Video output, for instance. So I'm guessing there's no easy way to get RGB SCART out of it.
-- Greg
Old 09-01-2010, 12:36 PM
radiopaque's Avatar
Unhappy
It is my experience that almost nothing with component connectors from the USA can actually be switched to RGB, unfortunately. My Arcam amplifier can do either RGB or component on the same R, G, B connectors, pretty neat. Then again, Arcam is British.
I think I'll be using a 300 in the home theater, and a 200 (bought JUST in time!) with the older TV. The 200 does have s-video, fortunately, and it works flawlessly.
Full RGB MorfiusX SageTV Media Extender 10 05-12-2009 09:56 AM
Video quality on PC monitor or TV with RGB ChrisR Hardware Support 4 02-02-2006 06:04 PM
VGA -> RGB SCART cable; flickery image Mahoney Hardware Support 6 08-25-2005 01:57 AM
VGA to Scart Converter Spies Hardware Support 0 08-18-2005 08:50 AM
RGB Downscaling Beelzebub Hardware Support 0 07-28-2004 05:52 AM
