SageTV HD Theater - Media Player Discussion related to using the SageTV HD Theater as a Media Player, i.e.: in use while not connected to a SageTV server. Questions, issues, problems, suggestions, etc. relating to using a SageTV HD Theater as a Media Player should be posted here. Use the SageTV Media Extender forum for issues related to using it while connected to a SageTV server. |
HD400 wish list
This was something I really hoped Sage would have put in, but maybe the next rev. With modern TV's all having Ethernet ports...I really didn't want to have to run two lines to TV area or hide another box. Is it possible the next time to put in a simple hub in the box. Thus, I can...in effect, daisy chain from the HD box to the TV...
Thanks in advance....owner of a melting credit card due to the HD300. |
That being said, I don't know popular that option would be. Adding a switch (2-4 ports) would up the power requirements and increase the cost quite a bit. I suppose you could post a poll to see how popular such an option would be. FWIW, the only reason I needed a switch is because my DishNetwork DVR is connected via Ethernet rather than telephone.
Server: i5-2405S (4 core @ 2.5 GHz), 8GB RAM, NORCO RPC-4220 4U case Tuners: 2 SiliconDust HDHomeRun , 2 Hauppauge HD-PVR Connected to 1 Pace700X and 1 TiVo Series 4 DVD Storage: 24 TB TV Storage: 11 TB (4x1.5TB for recording, 5TB for archive) Clients: 3 SageTV Extenders:5 |
$25 gets you a five-port 10/100 switch that you can put next to your TV to avoid running a second cable.
-- Greg |
And the reason they were able to make it so small is by leaving out extra connectors that most people wouldn't use.
-- Greg |
This has got to be a record. The HD300 isn't even available yet and we have a wish list started for its replacement
![]() I'm waiting for the "SageTV version 8" wish list thread.
More and more TV's will be plugged into a network. This is a fact. Last year alone they announced over 400 TV's with DNLA. This year it is 1000's. With Google and Intel getting to the fight...the amount will grow radically. In short, a network connected TV will be ubiquitous in the not to distant future. And yes...there is enough room, rotate the HDMI 90 degrees and slide the USB over. And yes...other CE products have done this (Sonos) already. |
It's not a bad idea at all. But not on the top of a must-have list of features for me. Upside: We have a year or two to debate the topic though
I think you are confusing the words CAN and WILL. Sure more TV's will probably come with network jacks. Will they actually be used by the mainstream consumer, my feeling is not anytime soon.
Sage on WHS HP MediaSmart Server EX495, 2 x Samsung EcoGreen F3 HD203WI 2TB 5400 RPM drives, HD-HomeRun Dual Tuner, HD-200, HD-300 |
You've got to draw the line somewhere on features. Quote:
Well, of course. All else being equal, more parts in the box means a higher pricetag. So you're going to pay more for it one way or another. The question is, should we all pay more so you don't have to buy a second box?
-- Greg |
Maybe by the time HD400 ships, it'll support hdmi 1.4 and might get ethernet over hdmi. If your tv supports hdmi 1.4, then your hdmi cable from your hd400 could also provide ethernet access as well
![]() I think that if HD300 shipped with a built in switch, then it still wouldn't be enough for some people... I have HD200, PS3, Xbox, and Bell PVR all using a network connection, which I have to run off a small switch near my AV equipment.
Let's not forget, you can easily correct your problem by adding the supported wireless USB adapter.
That would add to size drastically and most wouldn't like that alone let alone the price difference.
But seriously you don't even have this yet an already starting a wishlist to replace something you don't have.... Wow |
Remote LED
The remote IR receiver on 300 is great improvement.
But... after my HD200 goes off line, usually because I did a reboot upstairs the kids run into the problem that they don't know why TV is not working. I have got them to now look to see what LED's are doing. Hiding the unit out of sight would be great if I could remote the LED's to discreetly let me know status of unit. Maybe a custom HD400 IR remote receiver with status LEDs to let us know units status is needed. Or just a remote LED status cable as I am currently using a wirless Harmony remote and do not need IR reciever to be remote from unit behind TV. I am going to have a play with an old optic fiber cable to see if I can make a little 'light' shine out from under the TV using the units front LED. |
Also it would be great if it had a 7 speaker amp, could be recorded to directly, had a built in Blu-Ray Player, could update my facebook for me automatically, and could predict the weather more accurately than the local guys.
Sage has got to draw the line somewhere. You could tell Sage really listened to us on with the HD300 by adding an external IR receiver (completely surprised by this one), reducing the brightness of the LED, adding DTS decoding, and programmable television power/volume buttons to the remote. I personally would NOT want a built in switch. It is one more thing to go wrong and I would rather choose the switch than be forced to use whatever cheap switch is integrated into the unit and if that switch were to go bad I could be SOL. Just sayin....
I really hate the Sage extender remotes. The buttons you want to use are not where they are convenient. I would like a remote more like the TiVo or DishNetwork remotes. They are both human factored very well.
I guess I would rather see the TV itself have the Ethernet switch. Easier to hide the circuitry (and cost!) in the TV.
It really isn't a bad idea. Personally, I'd probably pony up the theortical $175 for the version with the switch (vs 150 without the switch) but only once the HD400 fully supports gigbit
![]() Although I too think it may only be a matter of time before you start to see network capable TVs with at least one extra network connection for convinience. and to the guys that are distgusted that people would dare to talk about an HD400... What else is there to talk about right now? The 300s haven't shipped. Should we be asking one more time to make extra double sure that the HD300 really, really, really, really does support HD audio bitstreaming? ![]() -Suntan |
-Suntan |
v6 wish list | GTwannabe | SageTV Beta Test Software | 10 | 10-07-2006 12:04 PM |
Why does the list look like this | cenwesi | SageTV Software | 7 | 01-27-2006 07:39 PM |
Want-list | dervari | SageTV Software | 8 | 01-14-2005 06:54 AM |
