Old 09-27-2010, 10:25 AM
Chriscic Chriscic is offline
Screen goes black when going to fullscreen or leaving fullscreen [RESOLVED]
Already submitted a bug report, but in case anyone else experiencing same behavior posting here.
When I go fullscreen the screen goes black. I can alt-tab away, but can't do anything with Sage except force close it. Same thing if I'm fullscreen and shrink to window, the window only contains black.
The next time I start up, it works fine until I try to change to or from fullscreen. Behavior seems to be the same whether I have fullscreen exclusive mode on or off.
This is Sage 7 latest RC on my Windows 7 64-bit PC. This is the first version 7 beta I've tried.
Old 09-27-2010, 03:43 PM
bs4free bs4free is offline
Hello Chriscic I too have the same problem I tried everything it i have it down to Aero. If you disable aero in windows 7 change your theme to a classic high contrast color theme when that is done Fullscreen will work.
A few other have posted about this in the below thread
http://forums.sagetv.com/forums/showthread.php?t=30241
Old 09-28-2010, 09:09 AM
Thank you for the info! I wasn't entirely clear from the linked thread, but they must be working on fixing the issue.
I already went back to version 6 for the time being; I just had the trial of 7 installed temporarily on my main PC after my WHS server crashed (now back up). I plan to migrate to 7 once the release version is out.
I hope they do fix it so I can run Sage 7 client on my main PC without having to mess with changing the themes.
Cheers,
-Chris C.
Old 09-28-2010, 09:37 AM
jerryt jerryt is offline
I got this bug going from 7.0.16 to 7.0.17 on win7 X64
I use Ctrl+Alt+Delete plus clicking on black screen to refresh the Sage UI. So I don't have to kill the running Sage.
Glad to know it is not just my system having this problem.
Old 09-28-2010, 10:25 AM
dmgbois dmgbois is offline
I am having the same exact issue, Windows 7 64-bit. Issues exists with and without exclusive mode.
Old 09-28-2010, 04:01 PM
jorton jorton is offline
Same problem, win7 64 bit.
Jeremy
Old 10-03-2010, 11:13 PM
HuDuVuDu HuDuVuDu is offline
Same Win 7 x64
Old 10-05-2010, 03:27 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
This is fixed now for 7.0.19 which'll be out later this week.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 12-02-2010, 01:12 PM
mickdaly's Avatar
mickdaly mickdaly is offline
I've seen something similar for quite a while - I have P/S running in a window on my desktop, while using other apps. After some time (during which other windows have overlayed the P/S window) I find the P/S screen is black. Only stopping P/S and restarting will fix it.
I use Windows 7 and am on the latest rel. of Sagetv server and P/S.
Mick
HP Mediasmart EX-485 server with 4.5tb storage, running Sagetv 7.0.23; 2 Hauppauge HD-PVRs; 2 Directv Receivers (H20 and H21 channel changing by usb/serial/usb cables); 4 Sagetv HD-200s; 1 Sagetv HD-300; Carada Criterion 126" screen; Definitive Technology speakers (UIW RLS II x 3, UIW BP/A x 2, DI 5.5BPS x 2, IWSub 10/10), Pioneer KRP-500M Kuro plasma; Pioneer Elite SC-07 receiver; Panasonic TH-50PH9UK plasma; Sharp Aquos LC-C4067U LCD; Oppo BDP-83 Blu-Ray player.
SageMC rendering issues when switching between Fullscreen and non Fullscreen. m1abrams SageMC Custom Interface 1 05-10-2008 05:26 PM
Fullscreen in linux shamgar03 SageTV Linux 5 09-21-2006 09:43 PM
Fullscreen On Tall Screen trothwell SageTV Software 1 06-04-2006 08:02 PM
Resolved yet? Another blank/black screen post. eehtpc SageTV Software 0 01-22-2006 07:11 PM
Request for Customization -- Allow Screen Saver if video not fullscreen dougrob SageTV Customizations 4 08-19-2005 02:19 PM
