Old 09-28-2010, 12:14 PM
Helheim Helheim is offline
HD300 Power Adapter
Why did they have to change the power adapter on the HD300? It would have been nice if I could have just unplugged the HD200 and plugged in the HD300 but no I had to take my whole entertainment unit apart to change the power adapter (it’s built into the wall). It wasn't bad enough it was a different size plug but also the direction of the wall wart is different so it wouldn't fit on my power bar either and had to go get an extension. What should have been a 2min job turned into a 2hr ordeal.. End rant
Old 09-28-2010, 12:20 PM
drewg drewg is offline
And the wall-wart plug is *huge*! When upgrading from my HD300, I had to run an extension cord from my power strip just so that I could plug the HD300 in.
Drew
Server HW: AMD Ryzen Threadripper 2990WX 32-Core
Server SW: FreeBSD-current, ZFS, linux-oracle-jdk1.8.0, sagetv-server_9.2.2_amd64
Tuner HW: HDHR
Client: Nvidia Shield (HD300, HD100 in storage)
Old 09-28-2010, 12:41 PM
I do agree that it would have been nice if the walwart had the same connector on the HD300 as the HD200. I had the same annoyance when I had to add it to one of my entertainment centers. Oh well. If I only have to do this once every two years, I'll take it (when the HD400 comes out, I will do the same swap )
Old 09-28-2010, 12:51 PM
voidpt's Avatar
voidpt voidpt is offline
Could have been worse: same plug, different voltage? Now that would have created a few threads
SageTV 7.1.9 (headless/service) • JavaRE 1.6.0_37 • 2x FloppyDTV C/CI (DVB-C) (fw: 1.2.10 B43110) (CAM: Conax) • Win7 x64 • Intel E3-1245V2 3.4GHz • 16GB PC3-10600 ECC • ASUS P8C WS (Intel C216) • APC Back-UPS RS 800 • STP-HD300 Extender (fw: beta 20110506 0) - HDMI/SPDIF - Yamaha RX-V2700 - HDMI - Sony KDL-52X2000
HD-200 power adapter jluster SageTV Media Extender 15 02-09-2012 06:18 PM
hd300 power adapter compatibility with hd200 impro SageTV Media Extender 4 09-10-2010 12:38 PM
Replacement power supply/adapter for SageTV Media Extender moakes Hardware Support 2 06-14-2009 09:11 PM
Media Extender Australia - Power Adapter zbobz SageTV Media Extender 17 02-16-2007 11:22 PM
