Utility: SageChanger STBs firewire channel changer for Windows
SageChanger version 0.2 beta.
SageChanger is a STB firewire channel changer for Windows. It's a replacement of timmmore channel.exe. If you ever missed a recording because your STB was OFF, you need this new changer because it will ensure that your STB is ON before issuing channel change. It also support querying power status. Usage SageChanger [-n <ID>] [-c <channel#>] [-f <changer#>] [-psvhtq] Options (case sensitive): -n <uniqueID> of target STB -c <channel number> -f <changer> force channel changer: 1 = SA3250HD 2 = SA4200HD (and some 3250s) 3 = SA4250HD 4 = SA4250HDc (and some 8300HDs) 5 = SA8300HD 6 = Motorola Fast (DCH and DCT series) 7 = Motorola Single-digit (default) -p Ensure STB is ON before issuing channel change. -q Query STB power status. Returns 2=ON, 1=OFF, -1=Error. -s Search for installed STBs and display informations. -t Test only. Do not send commands to STB. -v Verbose output. -h Display this help.It should work with other models too but you will receive the following message: UNKNOWN STB Please email the Vendor and Model ID along with the model number of your STB to: (hidden here). Please run SageChanger again with the -f option to force a channel changer for your STB. Since I don't own all those STBs myself, if you own one that are non tested, you can post your result for both commands (changer and power) and I will update the list below. To test do the following; 1- SageChanger -s --> That will search for STBs and take note of UniqueID. 2- SageChanger -n <UniqueID> -q -v --> That will query the power status of the STB. 3- SageChanger -n <UniqueID> -c 200 -v --> That will change the STB at channel 200. (adjust accordingly) Please report your success or failure at step #2 and #3. Post Vendor, ModelID, Changer and Power results, thanks! If you had success with it you can install it by following this if you use EXEMultiTunerPlugin and Channel.exe; To Install, simply copy the exe to any directory you want. Open the registry at "HKEY_LOCAL_MACHINE\SOFTWARE\Frey Technologies\Common\EXEMultiTunerPlugin" and edit the command key with this: "c:\WHERE_YOU_SAVED_IT\SageChanger.exe -p -n %DEVICE% -c %CHANNEL%" You are ready to go! List of Supported STBs Vendor......Model.......ModelID...version.....Changer....Power ----------------------------------------------Tested-----Tested Motorola....DCH-3200....0xd330....0.1 beta....Yes........No Motorola....DCT-3412....0x34cb....0.1 beta....No.........No Motorola....DCT-3416....0x346b....0.1 beta....No.........No Motorola....DCT-3416....0xb630....0.1 beta....No.........No Motorola....DCT-6200....0x6200....0.1 beta....Yes........Yes Motorola....DCT-6200....0x620a....0.1 beta....Yes........Yes Motorola....DCT-6212....0x64ca....0.1 beta....No.........No Motorola....DCT-6212....0x64cb....0.1 beta....No.........No Motorola....DCT-6216....0x646a....0.1 beta....No.........No Motorola....DCT-6216....0x646b....0.1 beta....No.........No Motorola....DCT-6416....0x646b....0.1 beta....Yes........No Motorola....QIP-6200....0x7100....0.1 beta....No.........No Sc Atlanta..SA3250HD....0x0be0....0.1 beta....No.........No Sc Atlanta..SA4200HD....0x1072....0.1 beta....No.........No Sc Atlanta..SA4250HD....0x10cc....0.1 beta....Yes........Yes Sc Atlanta..SA4250HDc...0x1f1f....0.1 beta....No.........No Sc Atlanta..SA8300HD....0x22ce....0.1 beta....No.........No Sc Atlanta..SA8300HD....0x206c....0.2 beta....Yes........Yes
Server: Sage 7 on WinXP with 1TB of storage NAS: Unraid with 6TB of storage Clients: 4 HD-200 and 3 Sage Clients PC Capture: 2 HD-PVRs + SA4250HDs Last edited by mikep; 11-07-2010 at 01:17 PM. Reason: Chart udpate |
Sweet!
I'm just about to do a full re-install just as soon a 7 goes gold. I wasn't looking forward to figuring out how to redo the timmoore FW setup from scratch and was, like many others, unsure of the future of FW tuning. A few questions. Will this support 64-bit any time soon? I assume the FW STB drivers are still needed as well as setting up ExeMultituner? How does this differ from Timmoores channel.exe? Anyway, ![]() ![]() ![]() S |
Do I assume that this still uses the drivers that are in Tim M Moore's package and that this program is a replacement for the channel.exe app?
Can I make a feature request? For some reason my STBs will occasionally drop the audio when they sit on the same channel for a long period of time (I am not sure how long but I think it is > 24 hours). This problem is fixed if you change the channel and then change it back. When you start a new recording in Sage if the recording is on the same channel as the previous recording then it doesn't actually cause the box to retune the channel so you get a recording with no audio. Therefore would it be possible to add a variation where the box will always change to another channel and then tune the correct channel. For example you could always tune channel 1, which I never record from since it is a preview channel, before changing to the channel that I want to record from. FYI - I use SA3250HDs with Sage connected to HD-PVRs and am running Sage 7.
Yes you still need to install STB drivers. I am not aware of 64bits version of these drivers. So your OS must be 32 bits!
It differ from timmore's channel, SageChanger support powering ON your STB! ![]() BTW: If you upgrade to Sage 7, your actual settings will remains Everything was still functionnal after my upgrade to Sage 7 beta! Mike
Server: Sage 7 on WinXP with 1TB of storage NAS: Unraid with 6TB of storage Clients: 4 HD-200 and 3 Sage Clients PC Capture: 2 HD-PVRs + SA4250HDs |
Mike
Here is a sample batch file to accomplish your needs;
If everything is put in c:\STBTools directory, just follow these step; 1- Save this batch in c:\STBTools directory, name it sa4250ch.cmd 2- Put SageChanger.exe in c:\STBTools directory 3- Edit EXEMultiTunerPlugin registry key to call your batch file like so; c:\STBTools\sa4250.cmd %DEVICE% %CHANNEL% Code:
@echo off rem tune to channel 1 c:\STBTools\SageChanger.exe -p -n %1 -c 1 rem wait 3 seconds ping -n 3 127.0.0.1 >nul rem tune to requested channel c:\STBTools\SageChanger.exe -p -n %1 -c %2
Thanks Mike - I will try that when I get a chance - unfortunately that might be a few weeks as I am out of town a lot in the next little while. Interesting to note that you use the same trick as I do for pausing a batch file - do a ping.
Are you on Videotron cable? They use similar hardware such as the Scientific Atlanta boxes to Rogers which is my cable provider.
Mike
Hi there!
I am having some problems getting this to work, but I REALLY want the the power check functionality. Here is the output of my SageChange -s: Code:
C:\Users\xxx\Desktop\SageChanger_0_1_beta>SageChanger -s SageChanger v0.1 beta Enumerating capture devices... Device #1. FriendlyName = Scientific-Atlanta AV/C Tuner Device Device #2. FriendlyName = Scientific-Atlanta AV/C Tuner Device Device #3. FriendlyName = Scientific-Atlanta AV/C Panel Device UniqueID = a8739eea1c00 VendorID = 0x00001cea ModelID = 0x0000206c VendorText = Scientific-Atlanta Inc. ModelText = Explorer(R) 8300HD DevicePath = \\?\avc#scientific-atlanta__inc.&explorer(r)_8300hd&typ_9&id_0#a873 9eea1c00#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global Device #4. FriendlyName = Scientific-Atlanta AV/C Panel Device UniqueID = c05bb4d71b00 VendorID = 0x00001bd7 ModelID = 0x0000206c VendorText = Scientific-Atlanta Inc. ModelText = Explorer(R) 8300HD DevicePath = \\?\avc#scientific-atlanta__inc.&explorer(r)_8300hd&typ_9&id_0#c05b b4d71b00#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global Device #5. FriendlyName = Hauppauge HD PVR Capture Device Device #6. FriendlyName = Hauppauge HD PVR Capture Device Code:
C:\Users\xxx\Desktop\SageChanger_0_1_beta>SageChanger.exe -n a8739eea 1c00 -c 652 -v -f 5 -p SageChanger v0.1 beta Enumerating capture devices... Device #1. FriendlyName = Scientific-Atlanta AV/C Tuner Device Device #2. FriendlyName = Scientific-Atlanta AV/C Tuner Device Device #3. FriendlyName = Scientific-Atlanta AV/C Panel Device UniqueID = a8739eea1c00 ***FOUND*** VendorID = 0x00001cea ModelID = 0x0000206c VendorText = Scientific-Atlanta Inc. ModelText = Explorer(R) 8300HD DevicePath = \\?\avc#scientific-atlanta__inc.&explorer(r)_8300hd&typ_9&id_0#a873 9eea1c00#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global Binding to object... Querying transport interface... Sending power status command group... Before: 0x01ffb27f After : 0x0cffb270 Accepted response. Power status is ON. Sending 1st command group... Before: 0x00487ce7 0x04028c00 0x00000000 After : 0x09487ce7 0x04028c00 0x00000000 Accepted response. Channel changed! Any thoughts? Thanks! |
Hi,
please test the following without -p switch: Code:
C:\Users\xxx\Desktop\SageChanger_0_1_beta>SageChanger.exe -n a8739eea 1c00 -c 652 -v -f 5 Mike
Thanks for the prompt reply!
No channel changing love there either unfortunately :-( |
Got it! I had to use -f 4, even though I have 8300HDs.
Thanks very much for your help! |
Mike
Great!.. I was replying ....
I will add your modelID 0x0000206c and will branch it to mode 4 automatically in the next release.
Mike
New release 0.2 has been uploaded.
You should try release 0.2 without -f switch and let me know if it work!
Ok, I have it working from the command line but I can't get it to work from Sage. There are a lot of moving parts!
I manually put EXEMultiTunerPlugin.dll in C:\Program Files\SageTV\Common I configured my two video sources each to use EXEMultiTunerPlugin to tune, but they have two different devices: EXEMultiTunerPlugin 3 EXEMultiTunerPlugin 4 Then, in C:\Program Files\SageTV\Common\RemoteCodes\EXEMultiTunerPlugin I have two files: 3.ir 4.ir that contain respectively: 3 38000 400 3 4 38000 400 3 Then inside the registry key HKEY_LOCAL_MACHINE\Software\Frey Technologies\Common\EXEMultiTunerPlugin I manually created a string value with name command and value C:\Users\xxx\Desktop\SageChanger_0_1_beta>SageChanger.exe -p -n %DEVICE% -c %CHANNEL% -f 4 Is that all correct? Its been about a year since the last time I set this up with channel.exe! |
You MUST rename 3.ir with your uniqueID. so a8739eea1c00.ir. That file must contain; a8739eea1c00 38000 400 3 You were using device number and not deviceid with channel. you must change both tuner accordinly, do the same with 4.ir, replace #4 with your other deviceid. You should also use version 0.2 and remove the -f 4 switch. Mike
.2 works from the command line without the -f switch.
I still can't get it to work from Sage though - i did as you suggested and created two new .ir files: a8739eea1c00.ir c05bb4d71b00.ir Then i went to the video source setup and changed each of my HD PVRs' tuner control: EXEMultiTunerPlugin a8739eea1c00 EXEMultiTunerPlugin c05bb4d71b00 and made my registry command: C:\Users\xxx\Desktop\SageChanger_0_2_beta>SageChanger.exe -p -n %DEVICE% -c %CHANNEL% did you guys ever make rube goldberg machines in high school :-) ? |
MODIFIED: Simple Utility to Control Multiple DirecTV STBs via USB or Serial ports | jchiso | Hardware Support | 10 | 07-05-2013 04:07 PM |
Any interest in a plugin to support/control the Sony XL1B firewire DVD changer? | TerryMathews | SageTV Customizations | 74 | 07-21-2011 02:24 PM |
Quick question about SA4250 and other STBs with firewire ports. | SDeGonge | Hardware Support | 2 | 06-17-2009 12:48 PM |
Simple utility to control multiple USB or Serial HD DirecTV STBs | jchiso | Hardware Support | 15 | 02-19-2009 06:27 PM |
Firewire DVD changer support... | briands | Hardware Support | 35 | 10-18-2008 04:00 PM |
