Old 11-17-2010, 08:30 AM
radiopaque's Avatar
radiopaque radiopaque is offline
Red face Power supply drowned!
Hi all,
I will not risk *all* my credibility by giving too much detail, but I managed to drown the 300HD power supply with a pumpkin this halloween. In my defense, it was a large pumpkin.
I wonder what the best way is to replace it, since I live in The Netherlands. A cheap, fast replacement from the United States would be fine, but if someone in the Netherlands (or elsewhere in Europe) knows a good "local" replacement, I am all ears!
Mark
CQC home automation and SageTV Server on Dell PE840 with 6TB RAID5 and two hauppauge tuners ; UPC cable TV ; Secondary headless unRAID on old Pentium 4 system with 3.8TB storage ; SageTV and AnyDVD on HTPC ; Arcam FMJ AV9 and P7, Anthony Gallo Reference AV speakers L/R/C and Gallo spheres for surround ; 50" Panasonic Plasma ; SB players throughout the house.
Old 11-17-2010, 09:45 AM
JetreL's Avatar
JetreL JetreL is offline
I am not familiar with the Netherlands store structure, if you were here I would recommend take the plug and go to radio shack but you should be able to get a replacement power brick that matches the voltage output at an electronics store and it work as long as the output plug is the same.
Google?? Facebook?? MySpace??
-=[If you don't pay for the product, chances are you are the product]=-
Old 11-17-2010, 10:02 AM
radiopaque's Avatar
True, but this power supply is fairly unusual, with a 2A current. Many stores over here will not have one in stock. I know I'll find one somewhere, but to be honest, I'm looking for the best (=cheapest!) solution .
Old 11-17-2010, 11:36 AM
JetreL's Avatar
Did a search for "12v 2a power supply" in Google found
here
here
Both under $10 before shipping. The amazon one looks just like the Power supply that I got from sage. Best of luck, hope it helps!
Old 11-17-2010, 01:09 PM
radiopaque's Avatar
here
here
Ah, I must say I did not try to google on American options. So when I followed your link, I realized I might as well look at Amazon.de and Amazon.co.uk. And bingo. 12 euros for a replacement , including shipping (together with a book). Thanks!
Power Supply Poll. What do you use? freewheeling Hardware Support 16 12-23-2009 11:22 PM
HD PVR power supply Fingergottes Hardware Support 1 09-22-2008 01:13 PM
Silent/80 Plus power supply? morikaweb Hardware Support 12 02-22-2008 11:54 PM
What's the best way to test a power supply? rdefino Hardware Support 6 10-23-2007 05:42 AM
Weak Power Supply ? 65 W Droid Hardware Support 4 03-04-2004 07:55 AM
