Old 02-07-2011, 10:42 PM
JustMe2 JustMe2 is offline
Sync or Link Two HD-300's
Is there a way to link or sync what is playing on two HD-300's to play the same thing simultaneously? I have one unit in our family room and another in the kitchen. However you can see and hear both at the same time and if they are not in sync if is very obvious. On occasion, I would like to be able to view the same file on both HD-300's. I have gotten pretty good at using the pause/play button to get them synced but that can be a real pain... Is there another way?
Old 02-08-2011, 12:12 AM
GKusnick's Avatar
GKusnick GKusnick is offline
No. If you require perfect sync, your best bet is to use a matrix switch or something similar to distribute the output of one HD300 to multiple screens.
-- Greg
Old 02-08-2011, 11:12 AM
jdamore jdamore is offline
This would be a substantial feature in my opinion.
Not only would it be good for tv/movies but also for whole home audio.
I couldn't imagine the amount of work needed to get this to work otherwise I would be requesting this all the time..!
Old 02-08-2011, 01:29 PM
QueOnda's Avatar
QueOnda QueOnda is offline
I needed this for superbowl but I had an echo like i there in the stadium LOL
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 02-13-2011, 04:35 PM
war10ck war10ck is offline
agreed. I have sage running in my kitchen as well as the living room and sometimes the playroom which are all in close proximity. whenever I try to watch the same in all rooms (like a sporting event) it is a pain to try to get them all exactly synced.
D-Link DWA-160 Spectrum SageTV Media Extender 0 12-17-2010 09:03 PM
How do you link a menu? SageGk SageMC Custom Interface 1 04-03-2008 09:32 PM
Narrow link Spies SageTV Software 1 06-24-2004 01:19 PM
v13 link sms SageTV Beta Test Software 2 02-28-2004 09:58 AM
What's the link to the beta? RBTConsultants SageTV Beta Test Software 2 01-23-2004 08:13 PM
