The SageTV Community Here's the place to discuss what's worth recording, HTPC deals at retail stores, events happening outside of your home theater, and pretty much anything else you'd like. (No For-Sale posts) |
Overclocking
To all the speed freaks: I just build an AMD system with a 6 core and DDR3 1333. I then used Asus' TurboV tool to OC the BIOS. I went from 3.2GHz to 3.7Ghz and all is stable and been running fine for a month. The one question I had was the memory OC. It went from a stock 1333 9-9-9-24, to 932 6-6-6-21. After some research, it sounds like lower timings are better than MHz...I just wanted to get some opinions to make sure that is a correct setting for the memory. I ran no benchmarks before, so I'm kind of blind.
P |
Lower timings as you stated are better as they reduce the turnaround time the RAM takes to fetch/store information, reducing the time the CPU waits for it.
As far as the timing being correct, that is impossible to tell at this point. Different timings are available for all speeds of RAM, and usually the lower timings cost more since they are guaranteed to run at these timings. RAM not spec'd for them can also do so, but not guaranteed to be 100% stable. Run an exhaustive memory test to ensure there is no data corruption from having the timings too tight. Grant |
Thanks. Right after I posted, I remembered I hadn't redone the WEI after the OC. I did, and CPU and memory jumped from 7.5, to 7.6...so it all worked out.
Thanks again, P |
Is this your Sagetv server?
Would building a powerhouse like this make navigating through menu's (with poster/cover art, ect) more responsive even through an HD extender? |
No, the server was built in 2007 and is still humming along. C2D E6600 and 2 Gigs of DDR2 800. Menus are fast, you shouldn't need monster power for Sage
![]() P |
Yeah I have E6600 and 2 gigs DDR 800 too haha. I'm using the asus P5B-Deluxe and with the "NOS" tuning set to overclock "20%" and its running as Asus's slogan says.. Rock Solid
![]() I was hoping to hear a super PC would make things in sage a little faster.. |
What's your Java Heap Size set to?
P |
I never touched that. I guess after all these years all have to stop ignoring it do my reading.
![]() Do you use any software for monitoring Mobo stats (voltages/temps)? How about bench testing? Years ago I used to use "burn baby burn" and Sandra.. Whats the good software these days? |
Can't go wrong with occt or orthos. Here is a basic guide that is pretty brutal and will expose any and all instability.
Overclocking stability guide
SageTV Server: unRAID Docker v9, S2600CPJ, Norco 24 hot swap bay case, 2x Xeon 2670, 64 GB DDR3, 3x Colossus for DirecTV, HDHR for OTA Living room: nVidia Shield TV, Sage Mini Client, 65" Panasonic VT60 Bedroom: Xiomi Mi Box, Sage Mini Client, 42" Panasonic PZ800u Theater: nVidia Shield TV, mini client, Plex for movies, 120" screen. Mitsubishi HC4000. Denon X4300H. 7.4.4 speaker setup. |
Overclocking Video Card | Dekard | The SageTV Community | 0 | 01-17-2008 12:32 PM |
Can E4300 handle HD Playback? * NO Overclocking * | castylx | Hardware Support | 27 | 08-23-2007 08:17 AM |
Overclocking CPU - problems with PCI-E | flavius | The SageTV Community | 0 | 04-13-2007 11:43 PM |
Overclocking Wiki | Dekard | The SageTV Community | 0 | 01-28-2007 08:59 AM |
