Old 07-10-2011, 07:56 PM
broderp's Avatar
broderp broderp is offline
Unhappy Comskip issues after installing v7.1.9.256
As the title states after updating to the above version, comskip ceases to work properly.
Any attempt to fast foraward or backwards or skip ahead or back disables comskip. I have to manually open the menu then re-enable it.
Pausing video does not affect this.
Any one have a fix for this?
Raymond
RIP: P4 3.0Ghz, ASUS MB, 2G MEM, ATI 1300X AGP VIDEO, PVR-150MCE & PVR-500MCE, 1 TB HD
NEW: DELL OPTIPLEX 755, 4GB MEM, ATI DVIX (DUAL) VIDEO, PVR-1250MCE & PVR-500MCE, 1.3TB HDD's
Old 07-11-2011, 11:06 AM
lotusvball's Avatar
lotusvball lotusvball is offline
To to verify that you are not crazy, I am having a ton of issue also with the new version. Mine keeps crashing in the middle of the night when my comskip files try to run.
Intel Core Duo 2.5mhz, 2gb RAM
Windows Home Server, Sage 7 beta
2 Hauppauge PVR-250, 1 PVR-500 MCE
1 HDHomeRun
4TB Storage, GB Network
2 MVPs, 1 HD100 & 1 HD300
Old 07-11-2011, 11:38 AM
nyplayer nyplayer is online now
Comskip is not working for me also it skips sometimes and sometimes it doesn't. I just use the left right to manually skip. I believe that John is aware of it.
Old 07-11-2011, 12:09 PM
mdnttoker mdnttoker is offline
I myself can manually skip, but auto skip is broken.
Old 07-11-2011, 12:52 PM
panteragstk's Avatar
I have to think that if this were a huge issue there would be more people. However, I have yet to install 7.1.9 so it may break for me when I do (not that I need to since my setup is rock solid). I may try tonight and report back.
Old 07-11-2011, 01:49 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
I am working on it, but it's proving a little problematical.
John
Old 07-11-2011, 01:54 PM
John
Is it something in v 7.1.9?
Old 07-11-2011, 02:26 PM
lotusvball's Avatar
Let me put it this way. Ver 7.15 runs fine. I upgrade to 7.19 and get a ton of problems. I put back 7.15 and everything is fine. I put back 7.19 and things go crazy. I put back 7.15 and everything is fine. so I would have to say YES it is broke. for me at least.
1 HDHomeRun
Old 07-11-2011, 03:09 PM
personalt's Avatar
personalt personalt is offline
I dont think you are crazy.... I went from 7.15 and 7.19 and seem to have lots of problems also..
* Comskip on at least of my TVs just plays through the skip points. It shows them but does not seem to care.
* a decent of amount of extender lock ups. I keep my extenders in the closet so I have a script to reboot them. I had not had to use them on 7.15 at all.
* sage once ran out of memory on 7.19
I am thinking about rolling back to 7.15 tonight..
Old 07-11-2011, 03:15 PM
graywolf's Avatar
graywolf graywolf is offline
Have you tried 7.1.7 or 7.1.8 ??
Old 07-11-2011, 03:29 PM
No issues for me on 7.1.7
Old 07-11-2011, 05:39 PM
JREkiwi's Avatar
I think there's at least a couple of differnt things that people are lumping in together here.
The problem with autoskip not working again once it has been temporarily disabled, I'm looking at.
lotusvball's problem of comskip crashing is something completely different.
John
Old 07-11-2011, 06:42 PM
broderp's Avatar
I feel a bit better knowing I'm not alone.
So far its been mostly com skip, but 7.1.9 has also reased all my remote control settings as well as shut off SageTv and not allow it to restart.
So far (Last 3 days) its been only the comskip. I can live with this as long as I know someone is working on it.
I hope the powers that be are looking at 7.1.9 and making changes! (I assume the auther of comskip is doing his part,
Raymond
Old 07-11-2011, 06:58 PM
tmiranda's Avatar
tmiranda tmiranda is offline
I've only been half watching this thread because I thought the issue had to do with the comskip playback STVi. Is CommercialDetector crashing or is comskip.exe crashing?
Old 07-11-2011, 08:04 PM
crusing crusing is offline
I have been having the issue of inconsistent automatic skipping. Sometimes it works and sometimes it doesn't. I updated several things at once (stupid I know) so I wast sure what the culprit was, but I am on 7.1.9.256 as well.
Old 07-12-2011, 05:49 AM
Wirenut Wirenut is offline
V 7.1.8
I've been watching this thread as I've been having auto skipping problems.
Sometimes it misses the skip, but shows the timeline marked. I believe this started with the latest comskip plugin that added the delay time feature.
I haven't gone to 7.1.9 yet. I use Dirmon2 to run comskip and that's fine. I just use the basic comskip plugin for edl files. ...I don't use the Commercial detector plugin that comes with a basic comskip file... I'm using the donator's version of comskip.
Mostly though it works. I haven't noticed any crashes of the client or major slowdown or spinning circles of death.
Old 07-12-2011, 09:25 AM
mr_lore mr_lore is offline
No issues here with comskip (donators) and the commercial detection plugin on 7.1.9, no extender issues either... Planned on doing a clean install to clean up my BMT setup, you guys are making me nervous...
Server: WMC Windows 7 64bit, SSD+2TB, Gigabyte 870G, AMD X6, 4GB DDR, ATi 5570
Capture Devices: HDHomeRun (OTA), 2x HD-PVR w/HTTP Tuning (DirecTV H21's)
NAS: Windows Home Server: Supermicro C2SBX, C2D 2.6Ghz, 4GB DDR, 32.07TB
Old 07-12-2011, 11:08 AM
Same here. Been on 7.1.9 since it came out and using the latest comskip stvi plugin (2.06 I think.) No issues skipping and certainly no issues like some have been describing. Keep in mind there were major issues and changes between beta 7.13/7.14 and 7.15. You may want to make sure you get to 7.19 with no issues and then reinstall comskip plugin.
Old 07-13-2011, 12:52 AM
JREkiwi's Avatar
I've uploaded a new version of the Comskip Playback plugin (2.0.7), which fixes (at least for me) the problem with autoskip not working after it's been temporarily disabled.
John
Old 07-13-2011, 03:53 AM
Polypro Polypro is offline
I've been up for a loooong time, so my eyes are probably shot. I just installed 2.07 and I thought previous versions allowed you to set the amount of time auto skip would be disabled when going backwards (like when CS starts the skip block too early and there is still some show left to watch in that segment). I'm not seeing it in the options...or was that never an option?
P
comskip error 1069 with installing on win 7 avogodro SageTV Customizations 3 11-18-2012 09:47 PM
Issues installing fresh copy of SageTV reboot_this SageTV Beta Test Software 1 06-17-2011 09:45 AM
Comskip Issues jlampson SageMC Custom Interface 1 01-12-2010 10:48 PM
Installing Comskip on multiple computers adone36 SageTV Customizations 3 08-24-2009 10:03 AM
