Old 08-21-2011, 07:50 PM
jorton jorton is offline
Phoenix Error
Not sure what this means but this appeared today after updating to the latest Phoenix (UI/API etc...)
Any ideas? Do you want some logs etc?
J
Old 08-22-2011, 07:18 AM
If you want, you can email the phoenix.log (from the logs area) and the sagetv_0.txt log if you have that. You can send it to metadatatools at gmail dot com.
For some reason the x-vfs.xml (which is the primary vfs for phoenix) is missing the "mediafiles" source. This source is defined, so for it to be missing either their was an xml error or their was an error with the phoenix.jar. I've seen times where sagetv has failed to extract a plugin package correctly. If you have bmt installed, can you check the phoenix version in the status screen on the bmt web ui?
You could also try to reinstall the phoenix-api and phoenix core plugins and see if that fixes the issue. (Sometimes even rebooting the server might fix the issue)
Old 08-22-2011, 08:35 AM
I think I just go out of sync on my server/clients with the lates Phoenix updates. I have to wait to restart my server once the morning kid's shows are recorded then I'll let you know.
Sorry, shoud have checked the server was ok prior to posting.
J
Phoenix Build 312 stuckless Phoenix 16 05-10-2011 10:32 AM
Phoenix API stuckless SageTV Customizations 264 03-17-2011 11:36 AM
Need help understanding SMM & Phoenix Fan Art SDeGonge Sage My Movies 1 08-29-2010 09:50 AM
