Old 01-06-2012, 11:59 PM
WellThen's Avatar
WellThen WellThen is offline
HD-PVR Cable Box Audio SPDIF Survey
Hello All,
I've recently moved my Sage server to a different WHSv1, so I got to set the HD-PVR up all over again. I was hopeful that the problems I had with SPDIF recording (some recordings have a crackling sound at the beginning, and then no sound) would be addressed by the fresh install and the newer HD-PVR drivers. However, these problems persist with the new setup.
This made me wonder if it's a problem with the Comcast Motorola cable box I have. Could folks reply with which cable box they have, and whether SPDIF recording is working for them? I know that many folks report that SPDIF is now working for them, so maybe we can see a pattern.
I'll start it off.
Cable Provider: Comcast
Box Brand: Motorola
Box Model: RNG150N
Change change method: Hauppauge IR Blaster (rock solid)
SPDIF Audio Recording Reliably: No
Old 01-07-2012, 03:37 AM
korben_dallas's Avatar
korben_dallas korben_dallas is offline
Cable Provider: Time Warner
Box Brand: Sci Atlanta
Box Model: 4250HDC, 3250HD
Change change method: USB-UIRT 2 Zone
SPDIF Audio Recording Reliably: on both yes
I just replaced my Colossus with a 2nd HD PVR because the Colossus couldn't handle optical audio.
SageTV server & client: Win 10 Pro x64, Intel DH67CF, Core i5 2405s, 8 GB ram, Intel HD 3000, 40GB SSD system, 4TB storage, 2x HD PVR component + optical audio, USB-UIRT 2 zones + remote hack, Logitech Harmony One, HDMI output to Sony receiver with native Intel bitstreaming
Old 01-07-2012, 06:06 AM
JerryB JerryB is offline
Cable Provider: Verizon FIOS
Box Brand: Motorola
Box Model: QIP 7216 1
Change change method: Firewire
SPDIF Audio Recording Reliably: Yes
Old 01-07-2012, 11:33 AM
darcilicious's Avatar
Cable Provider: Frontier (formerly Verizon) FiOS
Box Brand: Motorola
Box Model: QIP 6200
Change change method: Hauppauge IR Blaster (99% rock solid)
(I haven't updated the drivers in years though)
Old 01-07-2012, 08:46 PM
SteveD's Avatar
SteveD SteveD is offline
Cable Provider: Directv
Box Brand: Directv
Box Model: H20-600 and H23-600
Change change method: Serial Tuning paterson devices
SPDIF Audio Recording Reliably: Solid
Serv:ECS H61H2-T1 ITX I7 3770S CPU@3.1GHZ 8G Ram WIN1064 HDPVR, HD Homerun|network encoder Unraid Server:B75MU3B I5-3550 CPU@3.30GHz 9TB 16G Ram|Network HDPVR encoder:Win10 VM 8G Ram with Processor passthrough. Directv Http tuning to Genie, exemultitunplugin to Genie client. Http scheduled task bat file to defeat screensaver on Genie. Usb uirt scheduled task bat file to defeat screensaver on Genie client. Clients Android TV, Samsung TAB A
Old 01-07-2012, 09:57 PM
tvmaster2's Avatar
cox cable Motorola 6200 series I think. 1394 channel changing, and spdif audio, both working fine with a HD PVR with the drivers previous to the current drivers, on W7 32 bit
Old 01-08-2012, 12:06 AM
WellThen's Avatar
Thanks to everyone who responded so far.
I'm happy to hear so many people getting SPDIF audio to work well. To try to get a picture of what might be different, hopefully we'll also hear from some of the folks who have problems with SPDIF - if I'm not the only one left!
Old 01-08-2012, 01:30 PM
thomaszoo thomaszoo is offline
Box Brand: Motorola
Box Model: DCT-6200
The only recent problem I had with it was the power supply died. Prior to that I was having no problems with it and now that it is fixed, it appears to be just as reliable.
Wayne
i5-6400, MSI B150M Micro ATX MB, 16GB DDR3 1600, 2 - WD Green 2TB SATA Drives, Lite-On SATA 4X Blu-ray Reader, Corsair 400W 80+ Power Supply, Silverstone Sugo SG02-BF MicroATX Case, Windows 10 (64), HDHR Dual X2, Quatro and Prime, 5 x HD300 + 2 x HD100
Old 01-08-2012, 02:10 PM
Cable Provider: Rogers
Box Brand: SA
Box Model: SA3250HD and SA4250HD
I waited a longtime before using SPDIF to do the problems what others were having but since I have gone to it, which is abotu 1-2 years ago on two HD-PVRs, all has been well.
My HD-PVRs are also very reliable - except for the fact that both power supplies died. I wonder if bad power supplies were the root of many problems that people have had with the HD-PVR over the years.
Old 01-09-2012, 11:27 AM
Wirenut Wirenut is offline
Box Brand: SA/Cisco
Box Model: 2-SA4650HD's
SPDIF Audio Recording Reliably: Yes / Very stabile
Old 01-09-2012, 12:56 PM
DRB DRB is offline
Box Model: 4250HDC
Change change method: IR Blaster
SPDIF Audio Recording Reliably: never had a problem.
DRB
DRB
I WANT MY HDTV
Old 01-11-2012, 08:19 PM
WellThen's Avatar
Box Brand: Motorola
Box Model: DCT-6200
Wayne
Wayne,
What version of the HD-PVR drivers are you using?
Old 01-11-2012, 09:03 PM
I am using 1.0.5 (I know, it is getting a little bit old). Didn't want to mess with something that was working, and it didn't seem that I would be getting anything new that I wanted.
Wayne
Old 01-12-2012, 08:42 AM
equalize equalize is offline
Have you tried to take the cable box back to Comcast and get another one? The levels might be borderline causing the issue.
APEVIA HTPC case, ASUS Z87-EXPERT MB, i5-4670, 16G, Hauppauge QuadHD capture card. View directly from server, no extenders.
Old 01-12-2012, 08:51 AM
vividweb vividweb is offline
Just so you don't feel left out.
Cable Provider: Bell
Box Brand: Bell
Box Model: 6131/6141
SPDIF Audio Recording Reliably: NO (on all three boxes, with various revisions of HD-PVRs)
I need to try again with the latest (or possibly older) drivers. But have tried setting it up various times and eventually I get lock ups, without SPDIF I have ZERO lock ups.
Sage Server: i5-2500K 8 GB DDR, 6000gb HDD, 4xHD-PVR < 4xBell 6141, Win7 x64
Client 1: HD-200, Panasonic 42PX75
Client 2: HD-300, Samsung LCD
Client 3: HD-300, Samsung PN50C550
Client 4: MS Surface Pro
Old 01-12-2012, 09:09 AM
mangriotis mangriotis is offline
Elgin, IL
Box Brand: Motorola
Box Model: DCH-3200
HD-PVR
Hardware Revision: E1
Driver Version: 1.5.7.0 (dated 6/23/2010)
Windows WHSv1
m2
Old 01-13-2012, 06:49 AM
gdippel gdippel is offline
Cable Provider: Time Warner Cable
Box Brand:Cisco
Box Model: Explorer 4640HDC
Channel Changing: Firewire
SPDIF Audio Recording Reliable: Yes
I'm using the latest beta drivers, 1.6.29353
Old 01-13-2012, 10:32 PM
WellThen's Avatar
Yes, I'm on my second RNG150N. I may go back and ask for a different model of box. I actually did ask when I went to exchange the box, but all they had (for non DVR, with HD) was the RNG150N.
Cable Reception Survey itms Hardware Support 9 07-11-2009 02:24 AM
Ac3 audio over spdif bigbeav SageTV Placeshifter 7 07-04-2008 04:13 PM
No audio out using SPDIF Jesse SageTV Software 3 03-14-2005 08:48 PM
No Sound With Cable and SPDIF aitf311 General Discussion 2 07-31-2004 05:51 AM
