Old 01-12-2012, 12:25 PM
ellweber ellweber is offline
HD300 Power on/off control
I have done some searching and some experimenting but have been unable to find commands for "Power On" and Power Off" for the HD300.
In my experience, being limited to a "Power Toggle" is often problematic for universal remotes and particularly macros for more complex systems. When you get your remote 180 degrees out of phase with the device you are in big trouble! This is so easy to have happen if an IR beam gets interrupted at an inopportune time.
Does anyone have these commands or a work-around for this kind of issue?
Lynn
Server: Sage 7.1.9, service only, Java 1.6, Win XP Pro sp2, Asus M2A-VM, Athlon 64X2 4000+, 2 GB RAM, 2 x HDHR, 2 x WD 320 GB for media, OS on OCZ Vertex 60GB
Client: Sage 7.1.9, Java 1.6.0_15, Win XP Pro sp3, Asus A8N5X, Athlon 64 3500+, 1 GB RAM, Asus Silent nVidia 8400GS, WD 250 GB SATA for OS and local storage, Sanyo PLV-Z4 1280x720 LCD
Sage HD300 with Sony KDL40XBR9 and Sony HTCT100 Soundbar
Old 01-12-2012, 01:19 PM
Check out this thread: http://forums.sagetv.com/forums/showthread.php?t=35464
It also works for HD300s.
EDIT: Oops, sorry, I see you are looking for IR remote commands. Nevermind...
Last edited by KeithAbbott; 01-12-2012 at 01:20 PM. Reason: Apparently can't read...
Old 01-13-2012, 01:24 AM
HOME works as a power on command. There are also separate "Power On" and "Power Off" sage commands, though I don't think the HD300, by default, has anything trained for them (you can check by navigating to Setup -> Detailed Setup -> Commands -> Link Infrared/Keystroke to SageTV Command, and scrolling down to Power On and Power Off (commands 43 and 44).
Old 01-13-2012, 02:26 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Personally I don't bother to power mine off. "Off" doesn't really turn it off, or reduce its power consumption in any significant way. It just blanks the video output. So I leave it on, and just turn off the TV.
-- Greg
Old 01-13-2012, 03:00 PM
This
Old 01-13-2012, 03:32 PM
Thanks Fuzzy and GKusnic
Using Home for on and a sequence of Home followed by Power Toggle should solve my problems for now. Thanks for the suggestions.
As far as leaving the extender on, I am concerned it would prevent my server from sleeping and getting that to work (most of the time!) has been difficult enough.
It is working MUCH better now, thanks again,
Lynn
Old 01-13-2012, 08:00 PM
There are a couple auto-sleep timer plugins I think (I think i even made one) that will put the extender (or client UI even) to sleep. This will allow the server to sleep if nothing else is recording or being played back.
Old 01-13-2012, 09:42 PM
It also stops all playback which is handy to make sure something like LiveTV doesn't get left on accidentally, especially handy if you've got a system shutdown macro.
Old 01-20-2012, 10:05 PM
jchiso jchiso is offline
What type of remote do you have? If it's a Pronto-type or one that can accept the code from a such a remote, or if it's a JP1-editable One-For-All, RadioShack et. al -type there are discrete commands available.
Old 01-21-2012, 10:11 AM
I am using a Harmony One from Logitech. I have been using the remedy I mentioned a few posts above and have more or less completely solved the problem. Logitech does not show any on or off discrete codes in their database that I can see. There may be something in the JP1 community but I have not used a JP1 style remote on this system though I do have on on my Sage Client system.
The Harmony One is able to learn from an IR input so if I have further trouble I could go through the gyration of tracking down the discretes and using a JP1 remote to teach the Harmony One the code. Ughhhh!
Thanks for your comments...
Old 01-21-2012, 03:34 PM
Is your Client with the JP1 remote using HD100 (HD-X00) commands? If so, you could learn the discrete commands from that remote with the setup key and the following EFC commands:
  • Power On: 236
  • Power Off: 012
Old 01-21-2012, 03:38 PM
I don't think so. It is using commands from the Sage Client remote for Client input. That system predates all Sage Extenders and has never used one at all!
I really think it is going to be ok as the Home command will turn it on for sure and if the Home/Pwr Toggle sequence fails to turn it off then it will time out and go off anyway. II did install one of the auto power off plug-ins per Fuzzy's suggestion above.
I have not had a problem since I implemented these changes a week or so ago.
I do appreciate your suggestions.
Lynn
Why does the HD300 Remote Control turn on/off HD300 in other room? mkanet Hardware Support 2 09-21-2011 10:55 AM
HD300 - Stop Auto-Power On? Syrius SageTV Media Extender 7 03-16-2011 07:28 PM
HD300 Power Adapter Helheim SageTV Media Extender 3 09-28-2010 12:51 PM
hd300 power adapter compatibility with hd200 impro SageTV Media Extender 4 09-10-2010 12:38 PM
Control HD PVR power babgvant SageTV Beta Test Software 0 08-09-2008 06:00 AM
