Old 02-13-2012, 12:20 PM
phelme's Avatar
phelme phelme is offline
Favorites: Keep At Most, AutoDelete & "Jeopardy!"
Maybe I need a refresher on how AutoDelete works. I have "Keep at Most" set to 5 for my Jeopardy! favorite and AutoDelete set to "Yes", but SageTV just piles up the recordings and ignores the limit of 5.
Might it have something to do with the show ID's for Jeopardy!?
Or, just had another thought. Could it be due to a SJQ job that compresses them through Handbrake, even though I copy the metadata to the new file?
What am I missing?
Old 02-13-2012, 12:50 PM
Slugger Slugger is offline
I'd investigate this. Can't remember for sure, but if you're doing something with SJQ where you're deleting the media file obj in wiz.bin and relinking the metadata after importing the compressed video then I believe the core marks the new imported copy as "Archived" and "Manual Record", which, if it does, would explain why your keep at most is being ignored. You would need to remove the archived flag (I think) and remove the manual record flag (for sure) after relinking the metadata to the new compressed video.
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 02-13-2012, 01:01 PM
phelme's Avatar
Thanks for checking in Slugger. I looked and after relink they aren't marked Archived or Manual. The only thing I know is they lose their tuner info in the process.
Old 02-13-2012, 04:09 PM
If they are losing their tuner info, then they are being unlinked from the original Airing object. This is likely removing them from the autodelete consideration.
Old 02-13-2012, 04:24 PM
phelme's Avatar
Well, maybe this is it then. There is no way to place captured tuner info on another object via the Sage API that I can find.
Old 02-13-2012, 06:01 PM
GKusnick's Avatar
GKusnick GKusnick is offline
In the stock UI, go to the Favorite Details screen for that Favorite and click Additional Airings. Then click on the Current Recordings folder. That will tell you which recordings Sage thinks are controlled by that Favorite and thereby subject to Keep At Most and Autodelete. If your recordings aren't in there, then something is happening to make the Favorite not recognize them anymore.
-- Greg
Old 02-13-2012, 06:13 PM
Best thing to do in your conversions, is to not rename the file. (keep it named the same, including the mediafile ID) It should update the reference when sage scans it in. Changing the extension is fine. This is how the built-in conversion does it.
Old 02-14-2012, 01:30 PM
phelme's Avatar
Well, that's a handy tip.
Yep, they are being "lost" to Favorites. What's interesting is that Jeopardy! is not alone, a lot of my favorites are no longer managed by the rules that recorded them in the first place. (Heh, I think I had noticed on occasion that "Add this show as a Favorite" was on the recording options of some of these and never looked into why.... duh. ).
There does appear to be a pattern emerging, recordings made via the Silicon Dust Prime and converted (via Handbrake) appear to all be "lost" to the Favorites manager, those recorded via HD-PVR's and converted by the same script are not. They're both recorded as transport streams so I'm not sure what, if anything I'm doing differently to them.
I'll have to go back over the script. The file names are kept intact throughout with only the change of extension. One last step I added in the last 6 months is resetting the time stamp to match the original's. There could be a Comskip and Commercial Detector angle in here too I'll need to look at.
Thanks everyone for the help!
312 - can't add new favorite though "manage favorites menu" Gustovier Phoenix 2 05-02-2011 11:14 AM
"Backdrops" "SageTV" "Covers" folders - what's creating them mp328 Sage My Movies 4 09-20-2010 05:31 PM
What can be set for "added default settings for new favorites" nstocke SageMC Custom Interface 1 02-18-2009 07:00 PM
"Set defaults" for Series forgets "Keep"/"Auto-delete" setting maxpower SageMC Custom Interface 9 05-14-2008 09:44 PM
Suggestion: More "days" options for Advanced manual favorites TwistedMelon SageTV Beta Test Software 0 10-28-2005 06:45 PM
