Old 02-15-2012, 10:17 AM
heffneil heffneil is offline
Properties file
Do I need the .properties files with all my movies? I am using unraid and there are multiple copies of these files all over the place. I would like to just kill them and hopefully never create them again Any ideas?
Neil
Old 02-15-2012, 11:27 AM
MattHelm MattHelm is offline
If you are using no 3rd party plugins that display movie info (BMT, etc.) and want to see that info in SageTV, you need those. That is where SageTV gets the info. If you don't want to see it, or you are running a plugin that adds them to the SageTV database, you can delete them.
Move one elsewhere, reset SageTV, and browse to the movie, and see if you like what it shows!
Old 02-15-2012, 11:31 AM
I'm using BMT but I Thought it was stored in the database. What plugin puts that data in there? I realize we might have this thread in the wrong place now
Neil
Old 02-15-2012, 12:32 PM
Neil
SageTV create the .properties. It used them when/if the data in the database become corrupt. (it happens).
Old 02-15-2012, 03:49 PM
Can't the .properties be re-created if the database becomes corrupt?
Neil
Old 02-15-2012, 03:53 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Re-created from what? When a plugin writes metadata to the database, Sage appends a copy of that metadata to the .properties file as a backup. If you lose both the database and the .properties file, where else is Sage going to recover the info from?
-- Greg
Old 02-15-2012, 03:58 PM
I have no idea where the properties file came from in the first place?
Neil
Old 02-15-2012, 05:35 PM
Neil
If you have a metadata plugin installed (ie BMT) then it will update the metadata for your mediafiles/recordings. When this happens, as GKusnick noted, the data gets written to the wiz.bin and sagetv appends the values to the .properties (or creates them if they don't exist).
Old 02-15-2012, 06:50 PM
Understood and yes I am running BMT but if I delete the .properties and I don't update metadata via BMT then the data already is stored safely in the wiz.bin. If the wiz.bin gets corrupted - and I Don't have a backup. I can always rescan metadata from the library and BMT will update the wiz.bin again?
Just want to make sure I am understanding this before I screw something up
Neil
Old 02-15-2012, 08:07 PM
Neil
That is correct.
BMT and Properties file? nyplayer Batch Metadata Tools 2 03-14-2011 08:20 PM
How to Edit Properties File Xiggy SageTV Software 3 01-26-2007 10:54 PM
Properties file RRR SageTV Software 10 08-24-2004 10:37 AM
Problems w/ Properties File RRSwan3 General Discussion 6 02-01-2004 12:23 AM
