Old 03-16-2012, 04:52 PM
Deacon Crusher Deacon Crusher is offline
Proper config for ISO playback on extenders
I can watch other formats of ripped movies just fine on extenders. To playback an ISO I currently have to go to the server and mount the iso on a Virtual Clone drive letter that is configured in sage as a movie import directory, wait for Sage to scan and then I can watch. Is there a way to automate that?
Server: PhenomII X4 810, 16GB, 4850, C: 256GB Samsung SSD, D: HGST 3TB, E: HGST 4TB, H: 3T Seagate, 1.5 TB on NAS via UNC, Win 10 x64,
Sage 9 Cable provider is Comcast, Schedules Direct
Tuners: 4 ATSC - 2 seperate HD Homeruns all via Channel Master CM2016 on roof, 6 cable via 2 hdhomerun primes (opendct), 1 HD-PVR (in tuner priority order)
Clients: Wired: HD300, HD200, HD200 running Squeeze Slave, Placeshifters, HD200 (via wireless N bridge)
Old 03-19-2012, 12:15 PM
will will is offline
Just wondering, why not just extract the ISO a folder format and let Sage play the DVD/Blu-ray files normally?
The ISO doesn't offer any compression so is there any benefit to trying to automate the mounting/unmounting of ISOs?
Will
OS: Windows 7
Players: 5 HD300s, 2 HD200s
Old 03-19-2012, 01:36 PM
I have tons of ISOs left over from old days when I preferred to have one file versus many per movie and XBMC handled ISOs great. have slowly been converting some to folder format, but takes time and am just looking for an easier way.
Old 03-19-2012, 02:14 PM
Slowly converting??
I have used 7-zip to un-compress ISOs to a folder. You should be able to select all your ISOs at once and use 7-zip to extract them. The extracted folders (assuming your ISOs are DVD/Blu-ray images) should work natively in Sage without any additional work.
Honestly, this will be a lot quicker than trying to get a mounting solution to work.
Will
OS: Windows 7
Old 03-19-2012, 06:27 PM
That said, Sage does the auto-mounting on it's own.. you have to have virtual clone drive installed, and have it configured for 2 virtual drives. then, sage should auto-mount them on playback...
still, folders is a better option, and will perform better as well. As mentioned, simple extracting each iso to it's own folder should be very quick.
Old 03-20-2012, 08:52 PM
FMAX's Avatar
FMAX FMAX is offline
lost iso's??
I just did a re-install, long time waiting...windows 7 64
I cannot get iso to be recognized as a video file.
.iso is included in the properties file...
I remember there was an old trick back in the day, anybody?
Got VCD running fine, cant see in video library???
Luv Ya Sage!! Hanging On!!
HD-100(x2), HD-200(x2), HD-300(x2), MVP(x2) ,HDHR-(original), HDHR-Dual, HDHR-Prime, SageDCT, Hauppauge HVR-1600 & 1800, Windows 7(64bit) Pentium Dual-Core E6300 2.8gHz, 4GB, Gigibit E-Net, Placeshifter(x2), Client (x1)...
I've Tried all Media Centers, Sage Still The Best!
Hmmmm, Google Fiber
Old 03-20-2012, 09:04 PM
Okay, that's the answer. I think I originally had only one virtual clone drive running, not 2, so hopefully now that i've upped it to 2 it will work.
And, fair point about 7 zip, I've stupidly gone through the mount the iso and then re-rip process instead of just extracting. I'll give that a try.
Thanks all
DVD Playback on extenders GovtMule SageTV Media Extender 13 02-28-2011 01:48 PM
blu-ray playback on extenders without problems -- yes -- how to Deacon Crusher SageTV Media Extender 15 10-17-2010 11:27 AM
new recording won't playback, in sage or on extenders Deacon Crusher SageTV Software 0 10-05-2009 11:38 PM
What are you guys doing for proper MKV file playback? bhyman1 SageTV Software 7 08-20-2009 06:20 PM
Can you use the same config for all extenders? wayner SageMC Custom Interface 2 02-23-2009 02:58 AM
