Batch Metadata Tools This forums is for discussing the user-created Batch Metadata Tools for SageTV. |
Error: Failed to get status for: Phoenix
I'm getting this error on BMT web UI. I noticed new media weren't getting metadata so I checked BMT and found the error. How can I fix this?
Mayamaniac - SageTV 7.1.9 Server. Win7 32bit in VMWare Fusion. HDHR (FiOS Coax). HDHR Prime 3 Tuners (FiOS Cable Card). Gemstone theme. - SageTV HD300 - HDMI 1080p Samsung 75" LED. |
Sometimes, I see that after an update... and clearing the browser cache usually helps. So, I'd try, and then I'd try another browser, just to rule out a browser issue... and finally, you can check the logs/phoenix.log and/or the sagetv_0.txt logs and see if there are any errors that look like it might be related (or send me the logs). (metadatatools at gmail dot com)
I updated Phoenix from the Plugin list and the error is gone, I'm on Phoenix 2.3.61 now with latest BMT also.
But BMT is still not fetching metadata for new media files. I see the media in SageTV, but no metadata, everything is blank. I looked at the logs but pretty clueless. Take a look if you have time. logs attached. Thanks.
The phoenix-metadata log is a concise log that shows entries for updates and failures.. and in your case... Quote:
Phoenix Error after deleting Phoenix UI | wayner | Phoenix | 9 | 01-03-2012 11:08 PM |
Problem with Phoenix landing page / Status | sflamm | Phoenix | 3 | 08-24-2011 10:12 AM |
Error Failed to get status for: | gclayto | Batch Metadata Tools | 15 | 06-11-2011 06:08 AM |
Convert "Status:FAILED" in all 6.4 betas... | forthehandyman | SageTV Beta Test Software | 12 | 02-12-2009 08:07 AM |
Error: Failed to Locate GUI Server | Todd3835 | SageTV Media Extender | 2 | 07-29-2007 01:03 AM |
