Old 06-25-2013, 02:08 PM
SteveW's Avatar
SteveW SteveW is offline
Weather Not Updating
Did I miss something? My weather has stopped updating as of June 21st. Radar still works ...
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, 36TB Synology 1019+ for DVD/Bluray Rips, Music, Home Movies, etc., SageTV Server 64 Bit Ver 9.2.6.976, HDPVR x 2, Bell TV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver
Clients: PC Client x 2, HD-300 x 2 (1 Using Netgear MoCA Coax Bridges), SageTV Miniclient on NVidia Shield x 3
Old 06-25-2013, 02:19 PM
aairon aairon is offline
Mine is updating normally I'm using the Google Weather by Opus4 version 2.0.2 it's listed in the plugins.
I don't know if that will help you or not.
I'm sorry I almost forgot, I did lose all weather data a few days ago and had to go to
setup>detailed setup>Advanced>check for update and it did update to current version 2013010701 if yours is different them you may need to update, I hope that helps.
Old 06-25-2013, 05:27 PM
Denali Denali is offline
Working here.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 06-25-2013, 08:40 PM
SteveW's Avatar
Originally Posted by Denali View Post
Working here.
Anyone else in Canada not getting their weather updated?
Old 06-26-2013, 09:29 AM
SteveW's Avatar
I'll have a look. Tnx.
Old 06-28-2013, 09:47 AM
SteveW's Avatar
Was able to add my location again as another locale and it was updating even though the primary locale wasn't and it was still the same place. Tried to change the primary to another city so I could then change it back to see if I could unstick it. Even when I changed it, I'd go back in and it still showed my locale still stuck at June 21s.
Shutdown the Sage server software, and restarted. Problem is now gone. Everything is updating. FYI if anyone runs into something similar...
-Steve
Old 06-28-2013, 10:46 AM
Good job Steve!
The Weather Channel eliminating free weather data feed iolaus SageTV Software 69 08-26-2012 11:17 AM
Weather not updating timg11 SageTV Software 1 03-10-2012 07:09 PM
Weather Short Term Forecast Not Updating voorhees SageTV Software 0 12-23-2011 01:26 PM
Weather Not Updating? rwc SageTV Software 5 02-12-2008 08:41 AM
Weather not updating Jackal24 SageTV Software 2 04-16-2006 08:59 PM
