Old 06-30-2013, 06:39 PM
MattHelm MattHelm is offline
HD-PVR AC hum in audio and video?
All,
My HDPVR has been working perfect, until Friday night. I'm now seeing AC hum bars in the video, and hum in the audio. It's not bad yet, but it bugs me.
Think it's the power supply or something on the board? My guess is the power supply, but was hoping for some other people's input.
Old 06-30-2013, 08:29 PM
aairon aairon is offline
That is almost always caused by a power supply issue, the hum will typically be either 60Hz or 120 Hz, often it's 120 Hz caused by a failing or failed diode.
It will eventually take out the filter capacitors as there aren't meant to handle that much AC and act as a low resistance path to ground for AC.
If it's showing on the video I'd say it's not long before total failure which can cascade down the path and cause further damage.
Old 07-01-2013, 07:58 AM
SHS's Avatar
SHS SHS is offline
Yup I have agree with aairon I try swapping the power supply with another one even if you have pull one form one other system to test it first
It away a dead give away if it showing up on other PC Client if not then some else is going on so be sure test the HD-PVR on another PC it also possible that HD-PVR supply is starting to give out after all there very bad about that.
What additional decoders are being used for H.264 Video, VC1 Video, & HD Audio? Opus4 SageTV Beta Test Software 3 10-24-2010 03:01 PM
Getting audio over HDMI from video card with no audio pass-through? Martoon Hardware Support 3 08-11-2010 12:30 AM
video/audio or video only stutter rnewman SageTV Software 0 10-13-2008 10:55 PM
Getting Video but no Audio RandyJohnson SageTV Software 1 01-26-2005 11:49 AM
No Jukebox audio , video audio works fine. RobertdeWit SageTV Beta Test Software 3 02-05-2004 09:00 PM
