Old 03-01-2015, 10:21 AM
Tiki's Avatar
Tiki Tiki is offline
Weather broken?
Using Sage 7.1.9 the built-in weather functions are no longer working correctly. Is anyone else seeing these problems?
Problem #1: Weather maps not drawing the map background -only showing the radar overlay and the "WU" Weather Underground logo. So, on a clear day, you see nothing but a blank screen, on a rainy or snowy day, you see some green blobs, but with no cities or states in the background, you can't tell where they aer.
Problem #2: Weather only updates if you check the weather screen and only in the morning. If I check the weather screen in the morning, the update time will be some time in the past hour. But, if I check it in the evening, it won't update (The update time and date will be from the last time I happened to check it in the morning, which could be today or could be a couple days ago).
I have several weather locations set up in different parts of the US and all seem to have this same behavior. Re-starting Sage or re-starting my computer don't seem to help. I see the same thing whether viewing locally at the server pc, or from an HD200 extender.
Is anyone else seeing these problems? Any ideas on how to troubleshoot?
,USBUIRT (multi-zone)
Source:
Comcast/Xfinity X1 Cable
HDHR, HVR-2250, HD-PVR
Old 03-01-2015, 01:40 PM
SVinzant's Avatar
SVinzant SVinzant is offline
I am seeing weather issues too. I haven't dove in to deep to see what is going on, it's def. not updating.
EDIT: I am seeing the exact same issues that Tiki is describing.
Old 03-01-2015, 06:41 PM
Thomas Wischgol's Avatar
Thomas Wischgol Thomas Wischgol is offline
I am seeing the same issues. It refused to update a few days ago but then a couple days later it started up again. The weather radar is still missing the background image though.
Old 03-01-2015, 07:21 PM
Denali Denali is offline
I've noticed the same effects. Weather not updating for several weeks mainly in the afternoon and the radar background for several days. The sagetv log shows:
"Weather Underground returned error status. Type: invalidkey Description: this key is not valid due to exceeding rate plan"
It looks like OPUS4 needs to look at the weather feature.
HTPC: Gigabyte GA-Z170XP-SLI, I7-6700, 16GB, Windows 10 Pro x64, Hauppauge HVR-1600, WinTV-dualHD, Colossus 2, Samsung 850 EVO 120GB, Seagate 3TB, WD 3TB, 3TB, 5TB, Java v1.8.0_231, SageTVx64 v9.2.1.826, Samsung UN60EH6003F, Dish ViP222K, ViewHD 1x2 HDMI Splitter.
Old 03-02-2015, 06:04 AM
Tiki's Avatar
I'm wondering if that key value is exposed some place where it can be edited (like in the sage.properties file). Maybe the answer is to create a personal account on Weather Underground so we can use our own key.
Source:
Old 03-02-2015, 02:57 PM
egeller egeller is offline
Hey Tiki:
I thought it was just me, but you described the symptoms I am seeing.
SageTV Extender:3x HD200 1x HD300 1xFireTV
Sage TV: 9.2, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, Playon
All in lovely Drexel Hill, PA
Old 03-02-2015, 08:24 PM
pjpjpjpj pjpjpjpj is offline
Saw these symptoms a week or two ago, then they went away, now they are back. The written forecast and alerts appear to be working, but not the radar.
Old 03-03-2015, 07:03 AM
willowpc willowpc is offline
Extended forecasts no longer displaying
Extended forecasts stopped displaying three days ago although overview screen is still being updated ok.
Old 03-04-2015, 09:38 AM
Opus/Narflex: I know you guys are obviously prioritizing your "real" work over SageTV (understandably), but can you at least let us know whether there will there be a fix to this issued eventually?
Old 03-04-2015, 03:37 PM
I noticed the lack of updates a while back, but I thought it was my system, since I was having computer issues at the same time, so I'm glad this topic was posted... someone is looking into why it is happening & hopefully it will get fixed soon.
Old 03-04-2015, 06:43 PM
Great Andy! It is nice to know that a software that was discountinued years ago is still getting support.
Old 03-04-2015, 10:45 PM
tvmaster2's Avatar
still the best program for the money I've ever purchased. can you imagine how great it would have been if development continued?
Old 03-05-2015, 07:34 AM
I would settle to just have ffmpeg updated, just to take care of the bad recordings from Comcast on the prime. But ya been playing with kodi and plex and I still can't find anything close to the hd300s I have. They just work as a rule the bad recordings seem to be the only problem I have. If I use the ffmpeg option in SageDCT I get micro blocking every now and then.
Old 03-05-2015, 03:09 PM
Maybe you should ask Andy to update the FFMPEG for SageDCT as that is where the problem is. ... This is not a SageTV problem as SageTV never supported the Prime.
Old 03-05-2015, 03:14 PM
I know that, but I thought this problem was tracked down to the ffmpeg on sage being the problem at one time. Something about the audio stream or something. If I run the bad file through sage convert it plays fine. I don't know if its the hd300 or Sage it's self problem.
Old 03-07-2015, 06:07 PM
BlueH2O's Avatar
BlueH2O BlueH2O is offline
My weather is not working either, but my experience is a little different than what some of you have described. Data has not updated since 3/5/15. If I try to re-set the location, I get "No locations were found while searching for" anything I type there. Re-installed the plugin, no effect. I thought maybe the full moon made it go mad.
Old 03-09-2015, 08:03 AM
I just reinstalled one of my SageTV servers and got the same "No locations were found while searching for" message. A couple of hours later I got my weather back without me doing anything. It looks like SageTV stored the location even though it gave the error message because when I started getting temperatures and forcasts later they were correct. I will check when I get home tonight and see if the locale is listed correctly.
Edit: knew I forgot something will check when I get home tonight if I remember.
Old 03-12-2015, 06:06 PM
Beaker's Avatar
Beaker Beaker is offline
Me Too
Same here.
"Worry does not empty tomorrow of its sorrow; it empties today of its strength." Corrie Ten Boom
Core-i5 6600k
16GB RAM
Hauppauge WinTV-QuadHD
Win10
Old 03-13-2015, 11:48 AM
Narflex's Avatar
Narflex Narflex is offline
Sage
We're aware of this problem and it should be taken care of any day now.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 03-13-2015, 12:00 PM
Brent Brent is offline
And amazingly enough, there's apparently an issue with the weather app on Google Fiber TV this week as well...
The Weather Channel eliminating free weather data feed iolaus SageTV Software 69 08-26-2012 11:17 AM
FYI - Google Weather Broken peterjb SageTV Australia/New Zealand 1 11-21-2011 03:07 PM
Downloaded Google Weather Update, No weather? symgryph SageTV v7 Customizations 3 11-18-2011 08:55 AM
Using Weather Network as a feed for Canadian Weather Fastrack SageTV Customizations 2 03-22-2009 09:47 PM
weather.com weather extractor for mlbdude2 1.8.7 (v1.0.1 / July 6) nielm SageTV Customizations 105 10-08-2004 06:54 AM
