SageTV Placeshifter Discussion related to the SageTV Placeshifter application produced by SageTV. Questions, issues, problems, suggestions, etc. relating to the SageTV Placeshifter software application should be posted here. |
Is PlaceShifter that bad?
I have not used Placeshifter but I have 2 licenses so I figured I would fire it up since I will be away at the Golf US open. So I monitored my server loaded up Placeshifter memory usage went from 389 to 1035. Mind you this is over a home network.
then Video played sound went !crack crack crack chipmunk chipmunk.. Totally useless. |
It really is pretty bad. The ffmpeg used to transcode videos is not updated and does not properly support interlaced 1080i or 480i HD-PVR recorded shows. It works ok for other content.
None of that changes the fact that Placeshifter's video & audio quality is now totally outclassed by other personal streaming products such as Plex or Air Video. I dumped Placeshifter for Plex long ago for these reasons plus the ability to stream and sync video to my mobile devices. I hope things improve with the open sourcing of SageTV.
Server: i5 8400, ASUS Prime H370M-Plus/CSM, 16GB RAM, 15TB drive array + 500GB cache, 2 HDHR's, SageTV 9, unRAID 6.6.3 Client 1: HD300 (latest FW), HDMI to an Insignia 65" 1080p LCD and optical SPDIF to a Sony Receiver Client 2: HD200 (latest FW), HDMI to an Insignia NS-LCD42HD-09 1080p LCD |
I actually still use placeshifter on my macbook.. never had a problem playing anything so far. it will play videos better then my HD 200
Locally or remotely? If locally then SageTV is doing no transcoding and you're getting the original file. Remote playback quality is poor restricted to 480p. No HD at all. As long as there's enough bandwidth available Plex will allow streaming of 1080p without buffering issues.
I use Placeshifter everyday to watch TV remotely over the Internet. I also have a Plex Server that I am using Phoenix plugin on to watch recorded shows on Android devices, kid's phones, tablets, etc through Android Plex Client.
Have you looked in the streaming Settings? I use the adaptive settings most of the time, have forced lower rates on low bandwidth connections in the past, don't have that problem any more though so I just use the Sage Adaptive setting. After thought: I should point out that I don't really care about 1080p TV. I am just happy to be able to watch TV or TV recordings remotely. The quality is fine for the purpose, for me. :-) For my movie collection I watch remotely with Plex. Last edited by dranockcir; 06-09-2015 at 06:20 AM. Reason: after thought :-) |
Placeshifter also needs some work on retaining the proper color spaces. Ever notice how Placeshifter playback in Windows is all washed out? The Mac Placeshifter doesn't suffer from this problem because it gets it right for some reason. I've rallied on the issue before. Yet another reason why I moved away from it.
"To each their own.", hence my after thought
I use a SlingTV with a HD200 - great HD streaming quality no hardware requirements (besides the SlingTV) and it works on all platforms (Windows, Mac, iOS, Android, and Linux (I think)).
I love it but I'm also running a server that is eight years old (the mobo/cpu at least) so I'm not going to be using any software options in the foreseeable future...
Will OS: Windows 7 Hardware: Intel Core i7-920 with 12GB RAM & an Adaptec 5805 with a Chenbro 36-port SAS Expander Case: Antec 1200 with 4 iStarUSA trayless hot-swap cages (20 drives max) Drives: 8 Toshiba/Hitachi 2TB drives in a RAID 6 & 7 Toshiba 3TB drives in a RAID 6 Capture Cards: HDHomeRun Connect Quatro 4, Hauppauge 60 HD-PVR Players: 5 HD300s, 2 HD200s |
All of the solutions listed in this thread work somewhat but they all have shortcomings. Plex is good for some content but it isn't good for watching shows that are still being recorded and it isn't so good when you want to use SkipFwd and SkipFwdx2 and I use these constantly when watching sports which is almost all of my TV watching. And I often watch shows that are still being recorded. The same for AirVideo HD. Placeshifter doesn't work for 1080i recordings which is almost all of my content. Slingbox works somewhat but then you suffer from a UI lag which makes navigating menus frustrating and somewhat thwarts using the skip keys for sports.
Placeshifter is sorely in need of a technological facelift. Currently is based on the now all but defunct MPEG4 Part 2 video standard. Processors have advanced significantly since and it should be updated to H.264 (MPEG4 Part 10) and allow HD resolutions.
Actually converting to 1080i is probably the hardest, since you have to re-interlace after resampling. |
PPV content is usually under strong copy protection(not legally viable for OTA broadcasters), and also is a very direct revenue generator for those providers, so again, it makes them money, so they have an interest in catering to that (still rather niche) market. Most consumers however, are either unable to tell the difference between 720p/1080i/1080p content, or don't care, so the mass market gets the option that allows the providers to maximize the amount of content they can push, which means their going for the lower resolutions so they can cram more channels in the same amount of bandspace. Last edited by Monedeath; 06-30-2015 at 07:39 AM. |
And that excuse doesn't hold for channels like ESPN and HBO that aren't OTA.
In the early days, I seem to recall it was for bandwidth reasons, though looking back, 1080i/720p60 shouldn't have a bandwidth advantage over 1080p30 (highest frame rate for 1080p in ATSC). It was probably some idea of temporal resolution. 1080i and 720p both offer 60fps temporal resolution for live content, 1080p60 would have been a lot more bandwidth. |
ESPN has other factors at play, and I'm more inclined to say they've decided quantity is a quality unto itself where they're concerned. Although I do recall their(and/or other organizations) offering 1080p versions of sporting events in the past(naturally, at a premium), if they think there is a market for it, and the financials are good enough to make the middle men like it too, it would happen. (Although I will admit sports is one case where (poorly informed) video-phile raised to the power of 1011 can come into play in major ways) However, 4k has largely rendered 720p/1080i vs 1080p rather moot, so we'll have to wait and see what unfolds on that front. |
Some BBC broadcasts are in a mode that shifts from 1080i/p
Martin |
I assume you are talking about the PC version of placeshifter. The Mac version is just about useless at this point.
I would love to see an overhaul of placeshifter if for nothing other than local lan viewing. It is a critical piece of the infrastructure. My wife and I have reverted to using vlc right from the file system. Mostly because we want 2x playback with audio. There are so many shows that are suitable to that playback speed. |
How do i use placeshifter? | rdefino | SageTV Placeshifter | 2 | 11-15-2009 08:12 PM |
Placeshifter | crazymateo | SageTV Linux | 4 | 08-29-2006 04:48 PM |
MP4 and Placeshifter | codacoda | SageTV Beta Test Software | 21 | 06-17-2006 01:24 PM |
Thanks for Placeshifter!! | ChePazzo | SageTV Placeshifter | 3 | 06-16-2006 04:27 AM |
