Old 04-05-2016, 01:30 PM
Daweeze Daweeze is offline
SageTV - ASCII Message Popup from External System Options
Hello,
I was curious what the best way might be to send an external ASCII message alert to a SageTV screen that would auto-disappear after a certain time without user interaction with the remote.
Also, if there is a good solution would it still work in v9 or would I have to wait for an update?
-Travis
Old 04-14-2016, 08:48 AM
awhenry awhenry is offline
You want InfoPopup: http://forums.sagetv.com/forums/showthread.php?t=49514
Unfortunately it looks like there is currently an issue installing that plugin in v9. However, I can confirm that the plugin works fine with v9 (I upgraded my v7 with it already installed), and performs exactly the function you are looking for. It is unfortunately unclear to me from that thread if the developer is working on fixing the install process though... Hopefully it does get fixed, because that is one of the few plugins I have that I consider absolutely indispensable, to the extent that I would really love to see that functionality incorporated as a core feature of SageTV.
Hope this helps.
Andrew
Old 04-14-2016, 09:29 AM
SteveW's Avatar
SteveW SteveW is offline
Hope this helps.
Last I talked to him he was. I think he's planning to move the files to another site. Somehow they got turned into zip files on the sage forum site. That's why they are not installing.
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, 36TB Synology 1019+ for DVD/Bluray Rips, Music, Home Movies, etc., SageTV Server 64 Bit Ver 9.2.6.976, HDPVR x 2, Bell TV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver
Clients: PC Client x 2, HD-300 x 2 (1 Using Netgear MoCA Coax Bridges), SageTV Miniclient on NVidia Shield x 3
Old 04-15-2016, 05:32 PM
Thanks for the info! Is there any way to install the plug-in manually at this time?
-Travis
Old 04-15-2016, 06:50 PM
SteveW's Avatar
-Travis
Possibly. I am testing Sage 7 on Win 10 and used my existing Sage 7 in Win 7 where Sage Popup is working and used it to reverse engineer getting it working on my Win 10 by putting files in directories and editing the Sage properties file...
Old 04-21-2016, 12:07 AM
shadeblue.com's Avatar
shadeblue.com shadeblue.com is offline
Please try InfoPopup v7.0.3
Sorry this has taken me so long to get fixed. Work .. Life .. Travel .. You Know :-)
Please try the newly posted v7.0.3 which should be updated in the plugin repository soon. This update seems to fix the install issue ... at least it did on my old (Windows XP) SageTV system.
Thanks, Robert
Server Hardware: Intel Core 2 Quad Q6700 2.66GHz CPU, 4GB DDR2 RAM, NVIDIA nForce 780i SLI Motherboard, GeForce 8600 GT, Seagate Barracuda 7200.11 2.5TB
Operating System: Windows XP Professional
HTPC/DVR Software: SageTV 7
Capture Devices: 2 @ Hauppauge HD-PVR (1212), Hauppauge WinTV-HVR-1600 ATSC/QAM, HD Homerun
Media Extenders: 2 @ Sage HD100 & 1 @ Sage HD200
Signals/Providers: AT&T UVerse, OTA ATSC
Set-Top-Box: 2 @ Motorola Box VIP 1200
Old 04-29-2016, 08:34 PM
Thank you very much. Works perfectly!
-Travis
Odd System Message waynedunham SageTV Software 1 12-18-2012 07:11 PM
System Message: null JonTom Phoenix 11 10-21-2011 10:06 AM
Anyone getting 'null system message'? Dingdul SageTV Beta Test Software 1 10-20-2010 07:40 PM
STV Import: CallerID/Message popup plugin nielm SageTV Customizations 294 08-12-2010 03:16 PM
HDHomerun and System Message Reports scm Hardware Support 11 09-30-2009 03:19 PM
