SageTV EPG Service Discussion related to the SageTV EPG Service used within SageTV. Questions about service area coverage, channel lineups, EPG listings, XMLTV, or anything else related to the service or programming guide data for SageTV should be posted here. |
EPG Lineup Lost
I am getting the "Channel Lineup Lost from EPG Server" error message again. Anyone else getting this message?
Central Sage Server Win 10 64 Bit, Two HD200, Three HD300, & One PC Client 21 TB storage. SageTv 64 Bit |
I received this error message today.
"Lineup ...... no longer exists on the EPG server. Updates to this lineup will no longer occur." |
Neither of my SageTV servers are getting these messages. Steve, did you run through that thread that you posted in last time this happened and make the properties file changes yet?
I don't remember. I will check and see.
If you are talking about removing the values from the strings 'server_update_ID' or 'expanded' from the FAQ then yes I did. I haven't have any problems with the EPG for awhile now, but it started again today.
That's the one. Sounds like one of the two EPG servers has a hiccup.
I just received the same message. Hopefully it is resolved in the next few days (as it was last time).
I see that one SageTV server is showing this warning now, too, as of about 11pm CST Sunday night.
I too lost both my lineups OTA and Cable this is very frustrating you cannot fully rely on the EPG server and the schedules Direct plugin is not currently being supported. I am nearing the end of my patience with SageTV ... maybe it is finally time to cut it totally off.
It has gotten to the point with me that I no longer want to jump through hoops to keep SageTV running. pri=2;type=1002;time=1467649684629;msg=The lineup "Digital Broadcast - 97217" no longer exists on the EPG server. Updates to this lineup will no longer occur.;VLineup=Digital Broadcast - 97217; pri=2;type=1002;time=1467649977306;msg=The lineup "Comcast Portland Regional Digital - Portland" no longer exists on the EPG server. Updates to this lineup will no longer occur.;VLineup=Comcast Portland Regional Digital - Portland;
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 07-04-2016 at 07:35 PM. |
In all honesty, for the handful of times that this has occurred in the past few years, I don't believe I've ever lost a recording due to this issue. Thanks to the wizard behind the curtain that typically remedies this.
http://forums.sagetv.com/forums/showthread.php?t=63217
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 07-04-2016 at 07:54 PM. |
I'm getting these regularly
I'm told that there was a problem which should now be fixed.
If you have gaps in the guide data after this, see that oft-posted FAQ about clearing a couple properties. Andy
Yes, we sure do appreciate it - thank you!
Thank you for your continued support! Been a long time since I have had to come back to see whats going on..
I miss you guys.. its 2016 and I'm still rocking the socks of my SageTV box |
Thank You.
SageTV is king. :Place rows and rows of bowing emoji's here:
So Much to Learn, So Little Time, I need a Nap. ![]() Intel Duo 3Ghz, Win10, PVR2250 Dual Tuners, SageTV v9, USB-UIRT, Two HD300, Schedules Direct |
I never really thought about it, but the occasional "Channel Lineup Lost" is probably one of the few, if not only, standard messages that can be "pushed" so to speak to the SageTV user to bring them back to the forum, and hopefully see that SageTV is open source now.
I'm told there aren't any errors on the EPG server at the moment.
What lineup does it say is lost? Andy
Channel Lineup Lost from EPG Server | KryptoNyte | SageTV EPG Service | 3 | 04-28-2014 07:12 PM |
TWC Rebuild of Channel Lineup - Lineup lost | gary201 | SageTV EPG Service | 14 | 11-08-2013 07:37 AM |
Lineup Lost | hemicuda | SageTV EPG Service | 80 | 10-28-2013 11:12 AM |
Channel lineup lost from EPG server! | wayner | SageTV EPG Service | 52 | 07-11-2012 12:24 PM |
Channel Lineup Lost from EPG Server | EdwardATeller | SageTV EPG Service | 3 | 04-20-2010 07:04 PM |
