Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Phoenix 3.0
Phoenix 3.0 This forum is for discussing the user-created Phoenix 3.0 custom interface for SageTV.
Old 10-21-2016, 12:11 PM
rnadeau's Avatar
rnadeau rnadeau is offline
P3 beta testing feedback
I'l be a beta or alpha tester. Am looking forward to it!!
Sage Tv Server-Amd 4200FX quad core, Asus Nvidia EN610 Hdmi out , 8 Gig Ram ,(3) HVR-1800, 3.5 terrabyte storage, Windows 8 Pro on sage 9.09 system . Media Server- 6 Terabytes on 5 drives, Amd x2 6000 8 useable gig ram on win 7 32 bit media server.
Old 10-26-2016, 10:14 PM
boukmandutty boukmandutty is offline
Willing beta tester if needed...
Old 10-29-2016, 07:25 AM
Initial Feedback...
It works fine... haven't tested it on the NVidia Shield, yet, but on PC it works and looks good.
Enhancement Requests
1. After installing the plugin and loading the stv, is there a hook before the UI is rendered, that can call phoenix.menu.ReloadMenus(). After I first installed the plugin, and then loaded the STV, the Ui was messed up. Had to restart sagetv. The reason is that phoenix-core isn't smart enough to detect that new menu files were added (I think that I need to handle this better in phoenix-core).
2. When you go into a view, first time, spinning cirlce (my guess it's scaling fanart). Can it scale in the background? (show placeholder and then render the scaled image later?
Old 10-29-2016, 08:37 AM
bialio's Avatar
bialio bialio is offline
I'll take a look at the ReloadMenus. I think the spinning circle is only the very first time you load up P3. If you see it more often I'd of course want to know.
PHOENIX 3 is here!
Old 10-29-2016, 08:41 AM
Yeah, the spinning circle is only the first time... I've been using it on the shield (for only a few minutes) and so far it all seems to be working great. Nice job!
Old 10-29-2016, 09:06 AM
Can the Menu width be a configuration property? I added my 2 common menus to main menu for unwatched tv and unwatched movies, but the unwatched tv [TV Shows (Unwatched)] is cut off
You can see the first item has ellipsis. (I can get around it by changing the label)
Old 10-29-2016, 10:04 AM
bialio's Avatar
I'm working on a quick filter feature that will toggle a view between watched / unwatched. You can do a not so quick filter no in the options menu.
So that's what I'd say is your best bet.
PHOENIX 3 is here!
Old 10-29-2016, 11:55 AM
bialio's Avatar
Here's the quick filter I was talking about. Two keystrokes to switch between watched / unwatched in a view. (Almost all of my stuff is unwatched so there's not an obvious difference in the pictures other than the header)
Options -> Select
PHOENIX 3 is here!
Old 10-29-2016, 12:11 PM
samgreco samgreco is offline
Can I pull in views created in P2?
EDIT: And Menus?
Old 10-29-2016, 12:14 PM
bialio's Avatar
Yes, right now it's basically a manual process (edit the P3_HomeMenu.xml). But any view should work OK (although I'm sure there's a view out there somewhere that will blow things up )
Menus will work fine also, the default menu is the single level flat one, but if you use a Phoenix2 style menu it'll work.
btl.
PHOENIX 3 is here!
Old 10-29-2016, 01:01 PM
My old stuff is in the ..\userdate\Phoenix folder. Do I copy these to the ..\SageTV\STV\Phoenix folders?
Old 10-29-2016, 01:03 PM
bialio's Avatar
The user data location should work fine still.
PHOENIX 3 is here!
Old 10-29-2016, 01:32 PM
Daweeze Daweeze is offline
Wow, looks nice. Great work. Using it on FireTV Gen 2.
Notes so far:
1) Had to restart SageTV service as indicated before to get it to work.
2) Feeling dumb here. Not sure where the Zipcode setup is so I can see weather that is accurate for my location.
-Travis
Old 10-29-2016, 01:38 PM
bialio's Avatar
Hit options on the home screen and then look for Weather.
PHOENIX 3 is here!
Old 10-29-2016, 02:01 PM
Ok got it...using the PC Client though. Thanks! Noted issues with that....
1 - Changing it in the Plug-In section of the Core Service with the windows client didn't keep the setting change for me on my PC.
2 - The MiniClient on at least FireTV using the FireTV remote when showing the On-Screen Keyboard doesn't appear to map the delete (backspace) function properly as the key (<<) highlights and depresses on screen but it doesn't delete the numbers. The mapping for the space key (>>) works as expected. I had to change it on my Windows Client. Now it works on the MiniClient. Though the Location shows as 90210999 in options. Weird.
-Travis
Old 10-29-2016, 02:54 PM
Hello,
Here is something I have run into. Is there any way to allow Pop-Ups from the Info-PopUp/Caller ID Plug-In to show up in P3? I use the PI to show info coming in from external automated systems.
-Travis
Old 10-29-2016, 02:57 PM
Not picking any of it up. I have 5 XML files in the VFS folder and 7 menu XMLs in the Menus folder. All of the menu files have the prefix: phoenix2.menu.lz....
I do notice that the only new menu file in the STV folder is the P3_HomeMenu.xml.
Old 10-29-2016, 03:34 PM
bialio's Avatar
It won't use the old files - it uses the P3_HomeMenu.xml.
What I meant was that you can put replacement xml files in the */userdata location and the Phoenix Core will read them and then subsequently P3 will use them - if they define a view or menu that P3 looks for.
The menu for P3 needs to be named "p3.menu" in whatever custom xml files you provide in /userdata.
Alternatively you can modify the p3/home/menu property in the .properties file.
Hope that helps...
PHOENIX 3 is here!
Old 10-29-2016, 03:56 PM
bialio's Avatar
Originally Posted by Daweeze View Post
Hello,
-Travis
That's not a plug in that was made for Phoenix - so it won't work. The owner of the plugin would need to create a version that is for Phoenix UI.
PHOENIX 3 is here!
Old 10-29-2016, 04:26 PM
I did most everything in P2 using the landing zone/menu editor built in to it. There are a lot of sub menus and such, so I think I will need to rebuild manually.
This may take a while.....
Beta 7 UI Feedback Asmordean SageTV Beta Test Software 10 06-12-2010 06:28 PM
quick feedback on today's beta cat6man SageTV Beta Test Software 3 03-17-2009 02:51 PM
jittering after testing new beta briefly Teg SageTV Software 2 11-14-2004 09:01 AM
Beta .11 feedback drbenson SageTV Beta Test Software 42 02-02-2004 10:01 AM
Second Beta feedback jominor SageTV Beta Test Software 9 01-30-2004 01:59 PM
