Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Gemstone for v9
Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 01-17-2017, 07:41 PM
gordyp's Avatar
gordyp gordyp is offline
Possible To Change Main Menu Title Order?
After installing the PlayOn and Gemstone plugins, they are appended to the listing in the Main Menu. I would like to move them so that 'Setup' and 'Exit' are the last two entries. I looked in SageTV7.xml and didn't see either PlayOn or Gemstone listed - could someone give me a push in the right direction to accomplish this?
SageTV Server:
i5-3470, 24GB, Radeon R7-240 2GB, 12TB, Win10 Pro 20H2, HDHR PRIME for Xfinity with OpenDCT 0.5.32; HDHR Connect Duo for OTA, Java: 64-bit 1.8.0_271, SageTV x64 9.2.2.903
SageTV Client:
i5-6600K, 16GB, GeForce GT730 2GB, Win10 Pro 20H2, Java: 64-bit 1.8.0_271, SageTV x64 9.2.2.903
Old 01-17-2017, 09:00 PM
jusjoken jusjoken is offline
if you are using gemstone then press options on the main menu, select menu manager and in menu manager move the menus around.
k
Old 01-17-2017, 10:04 PM
gordyp's Avatar
k
jusjoken - actually I am not at this point; I have both Gemstone and Phoenix installed, and have tried using them in the past (because some of the screen shots I have seen look pretty cool), but I have had issues with implementing both of them and just end up going back to SageV7 (with Serenity). For instance, with Gemstone I do not have any sub-menus from the Main Menu, as per the attached screenshot.
I guess I was hoping that it would just be a matter of rearranging the order of the items in an XML file to put the Setup and Exit items at the bottom of the menu...
SageTV Server:
SageTV Client:
Old 01-17-2017, 10:29 PM
You don't have JUST gemstone installed. It looks like you have another plugin messing with the menus. I think the 'Always Show Submenus' plugin exhibits that missing submenu behavior at time.
Old 01-18-2017, 06:26 AM
ranger ranger is offline
I've seen that behavior occasionally on my clients running Gemstone. It can occur randomly after sleep / wake or a loss of connectivity with the server. If I close the SageTV client and re-start it, the sub menus come back.
Old 01-21-2017, 08:22 PM
gordyp's Avatar
The apparent resolution was to completely remove all unneeded Phoenix and Gemstone plugins. I should have said that I have had issues in the past implementing either of them; I just used Gemstone as an example. I do have 'Always Show Submenus' installed. I also try to keep my Java current; I just saw in another thread that Gemstone and/or Phoenix doesn't work on Java 8...
I still would like to be able to rearrange the items on the default Main Menu so that 'Setup' and 'Exit' were at the bottom... but it is not a high priority; just thought I would ask.
SageTV Server:
SageTV Client:
Old 01-21-2017, 09:48 PM
The only way I know to change the main menu ordering on the stock UI is to use the ADM plugin.
Main Menu Order mbowling SageTV v7 Customizations 2 12-16-2012 03:31 PM
HD200 Main Menu & SageTV main Menu Doubletop SageTV Media Extender 2 12-29-2009 04:43 PM
SageMC - Main menu to Sagetv Main Menu shanrice SageMC Custom Interface 1 11-29-2009 01:41 PM
exit menu item on main menu 49studebaker SageMC Custom Interface 1 11-14-2008 03:27 AM
Where can I find the menu title theme (Main Menu, Program Guide, Setup Menu, etc) mkanet SageTV Studio 5 11-11-2005 04:55 AM
