SageTV for unRAID/Docker Discussion related to SageTV for unRAID/Docker. Questions, issues, problems, suggestions, etc. relating to SageTV for unRAID/Docker should be posted here. |
Be weary of unRAID 6.5
I upgraded my brother's server to unRAID 6.5 and I lost the web ui. After a couple hours I was able to start nginx and log into the server, but not good.
On my own server I upgraded to 6.5 and sagetv failed to start. It kept dying with an exception in the log... Code:
Sat 3/17 19:18:16.842 java.lang.NullPointerException Sat 3/17 19:18:16.843 at sage.CaptureDevice.isSameCaptureDevice(CaptureDevice.java:365) Sat 3/17 19:18:16.843 at sage.CaptureDevice.isDeviceAlreadyUsed(CaptureDevice.java:63) Sat 3/17 19:18:16.843 at sage.LinuxDVBCaptureManager.detectCaptureDevices(LinuxDVBCaptureManager.java:84) Sat 3/17 19:18:16.843 at sage.MMC.init(MMC.java:89) Sat 3/17 19:18:16.843 at sage.MMC.prime(MMC.java:65) Sat 3/17 19:18:16.843 at sage.SageTV.<init>(SageTV.java:405) Sat 3/17 19:18:16.843 at sage.Sage.startup(Sage.java:1170) Sat 3/17 19:18:16.843 at sage.Sage.main(Sage.java:950)
Thanks for the warning.
I will watch this thread as well - thanks for the heads up Sean!
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.8.0/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB EXTERNAL DEVICES: 4x HD-PVR's Firewire Channel Changing TUNERS:NO LONGER RECORDING LIVETV CLIENTS: 2xHD300 2xHD200 SONY ANDROIDTV MINI-CLIENT |
I'd have to double check, but I think I've been running 6.5 nearly since it came out with no issues.
-edit Nope, I was wrong, I'm still running 6.4.0. Not sure how I missed that 6.5 was out ![]() Last edited by stanger89; 03-19-2018 at 06:50 PM. |
I was home with a sick kid the day 6.5.0 came out so I upgraded right away. Have had zero issues with it.
Server: i5 8400, ASUS Prime H370M-Plus/CSM, 16GB RAM, 15TB drive array + 500GB cache, 2 HDHR's, SageTV 9, unRAID 6.6.3 Client 1: HD300 (latest FW), HDMI to an Insignia 65" 1080p LCD and optical SPDIF to a Sony Receiver Client 2: HD200 (latest FW), HDMI to an Insignia NS-LCD42HD-09 1080p LCD |
I got the exact same errors and couldn't solve it when I upgraded on 3/17/2018.
Because I have two tuners I was getting the message twice; looks like once for each tuner. My previous setup * Unraid 6.3.5 using unRaid DVB plugin with the LibElec drivers * Windows 7 VM for 2 HD-PVRs ** I passthru the USB controller for the 2 HD-PVRs and an USB-IIRT * SageTV Docker image using 2 Hauppauge 2250 ATSC tuners I couldn't roll back because the support for unRaid 6.3.5 was removed from the DVB plugin. I couldn't use UnRaid 6.4.* as my Win 7 VM was unstable. So now I have * Unraid 6.5.0 * Windows 7 VM for 2 HD-PVRs and the 2 of Hauppauge 2250 ATSC tuners ** I passthru the USB controller for the 2 HD-PVRs and anUSB-IIRT ** Also passthru the 2 Hauppauge 2250 ATSC tuners * SageTV Docker image It's working for now. I'll follow this thread in case anyone has any insight.
unRAID Server: FX8300, 32GB RAM, SSD Cache Pool 624 GB (3x256GB SSD,2x240GB SSD), Storage Pool: 3TB Storage Pool (3 storage disk + 1 parity disk, all 1TB) Docker: SageTV9, 2x HVR-2250 PCIe Cards (4xOTA) VM: Win7 SageTV9 Network Encoder (2x HD-PVR (connected to 2xSA4642HD-Rogers Cable controlled w/ USB-UIRT using multizones)) Clients: 3x HD-200 |
Tried the upgrade to 6.5 and it borked my SageTV container. It has no tuners available - using the 6.5 Digital Devices plug-in.
Reverted to the 6.4.1 Digitial Devices DBV version and my HDPVRs were all back as they should be. Not sure what to do or where the issue is coming from with 6.5? Adding two log files in case someone knows what to do ... FOLLOWUP I updated my Unraid version to 6.5.1-rc3 and the DVB Version to LibreELEC and SageTV and my Hd-PVRs are chugging along just fine! Not sure why the 6.5.0 versions would not work but at least I am updated now - just an FYI
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.8.0/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB EXTERNAL DEVICES: 4x HD-PVR's Firewire Channel Changing TUNERS:NO LONGER RECORDING LIVETV CLIENTS: 2xHD300 2xHD200 SONY ANDROIDTV MINI-CLIENT Last edited by dstanley; 03-31-2018 at 08:49 AM. Reason: Added Log Files |
Upgraded to 6.5.0 LibreELEC and lost my two HD-PVR's. My HD Homerun's were fine. I didn't really spend much time troubleshooting since I needed my live TV, so I installed 6.5.1rc3 and I'm back in business. It was a nerve-racking 45 minutes where I thought I lost all my DISH programming.
Any update on this, or are folks waiting for 6.5.1 before trying to upgrade?
6.5.1 Stable is released, anyone using it?
unRAID Server: Intel Core i5 7600K, 48GB DDR4, 2x512GB PCIe M.2 Cache Pool, 2x10TB SATA3 Parity Drive, 3x8TB SATA Array, 1x hdHomeRun DVB-T2 Quattro, IPTV via xTeVe, unRAID 6.8.3, tvHeadEnd for recording back end, Emby Clients: 3 Nvidia Shields, 3 FireTV, 3 Win10 Pro PC Clients |
I haven't braved it yet... but likely I'll give it a go this weekend.
6.5.1rc6 is working fine on one of my servers with SageTV Docker. I expect 6.5.1 stable to work fine. I'm not running HD-PVRs through it directly however. Everything is a network encoder. Either HDHR's or HD-PVRs from Windows VM for the 5.1 sound.
"Keep your goals away from the trolls" |
I installed it tonight. It booted up fine and I'll watch it. I have been using 6.5.1rc5 for two weeks.
Updated from UnRaid Server 6.5.1-rc5 to 6.5.1 release DVB LibreELEC Version without any issues.
I am running 4 HD-PVRs only on my server. Dwight
I updated to 6.5.1 release DVB LibreELEC Version and my HDHR Prime tuners are not accessible. I've tried stopping/restarting the stuckless-sagetv-server-java10 and crazifuzzy-opendct dockers to no avail. Both were working flawlessly in 6.4.1. And, being new to Linux and unRaid, I have no idea how to roll back. I really need some help on this. I did install a new modem, but believe everything was working Ok with that change. Goint to the Apps tab to use the Community Applications app, I get the following message: "Download of appfeed failed." Any help on this will be greatly appreciated.
unRAID Basic Server, Sage & OpenDCT Dockers, Core i3-8100, 8G Memory, HDHR Prime, HD300 Extender, Shield & Android Miniclient, Harmony Hub/Remote |
"Download of appfeed failed" sounds like you have internet connectivity problems.
You are so right. I changed my unRaid network settings to automatic and was able to get internet again and rolled back to 6.4.1; but, alas, I had to re-install my Sage video sources to the new IP address and now I get a blank screen, even though it acts as if it's tuning. BTW, thanks for the help.
Anyone try 6.5.2 which was released about a week ago?
Can you use SJQ from within unRAID | wayner | SageTV for unRAID/Docker | 4 | 06-29-2017 12:54 PM |
unRAID DVB 6.3.5 | wayner | SageTV for unRAID/Docker | 5 | 05-31-2017 06:35 AM |
unRAID 6.3 is out | wayner | SageTV for unRAID/Docker | 11 | 02-21-2017 07:32 AM |
WHS to W7 and Unraid - Have some ???s | icon123 | Hardware Support | 25 | 01-19-2011 05:50 PM |
unRAID | wrems | Hardware Support | 19 | 04-13-2010 02:32 PM |
