SageTV for unRAID/Docker Discussion related to SageTV for unRAID/Docker. Questions, issues, problems, suggestions, etc. relating to SageTV for unRAID/Docker should be posted here. |
Unraid 6.6.0 issues with HD-PVR
I tried installing the Unraid 6.6.0 and my HD-PVRs were not detected with the LibreELEC 6.6.0. I quickly reverted to the 6.5.2 and will wait a bit. If anyone has success with the HD-PVRs, I'd be glad to know it. My HD Homeruns were detected fine.
I wonder if the Digital Devices build would have worked?
Seems to me way back when I started with Unraid and SageTV and my HD-PVRs that was the version I used and somewhere along the update path over the years I started using the LibreELEC version. Now I am too chicken to try - ha!
SERVER: Intel Core i7-3770 CPU @ 3.40GHz - UnRaid Server 6.8.0/DVB LibreELEC with Docker stuckless-sagetv-server-java9 MOTHERBOARD: ASRock-Z77 Extreme4 / 32GB RAM CACHE DRIVE: SSD 1TB ARRAY: 24TB/7 DRIVES PARITY: 8TB EXTERNAL DEVICES: 4x HD-PVR's Firewire Channel Changing TUNERS:NO LONGER RECORDING LIVETV CLIENTS: 2xHD300 2xHD200 SONY ANDROIDTV MINI-CLIENT |
Either way, I haven't used it in a while and I'm not keen on playing around with my ability to watch media at the moment. Thanks! |
6.6.0 looks like a major release with lots of changes. Thanks for the update... I'll hold off upgrading until 6.6.1. Typically LibreElec kernel is pretty god about including all the necessary drivers. I wonder if anyone has let them know that HDPVR support appears broken. (HDPVR support is added in the LibreElect kernel, not really anything to do with unRAID)
Just for giggles, I tried Digital Devices 6.6.0 and it too does not detect either of my HD-PVRs. Back to LibreELEC 6.5.3.
Thanks Mibsy,
I was going to try it when I had time - guess we wait now ...
Anyone on 6.6.1 and having issues?
unRAID Basic Server, Sage & OpenDCT Dockers, Core i3-8100, 8G Memory, HDHR Prime, HD300 Extender, Shield & Android Miniclient, Harmony Hub/Remote |
Updated to 6.6.1 and SageTV running fine with my HD-PVRs:
Plugins - Update any if needed Dockers - Check for Updates - update any if needed Tools - Update Assistant - verify all is fine to proceed Stopped All Dockers Stopped VMs Settings - Dockers - disable Settings - VMs - disable Update OS to 6.6.1 from 6.5.3 using Unraid Upgrade Tool Reboot Settings - UnRaid DVB Editions - select LibreELEC 6.6.1 - Install Reboot Settings - VMs - enable Settings - Dockers - enable Test SageTV tuners - HD-PVRs all functioning correctly. Please note that I do NOT have any other tuners installed except the HD-PVRs so I am uncertain how they may be effected. However, reverting to 6.5.3 should be relatively easy by choosing it through UnRaid DVB Editions. If anyone else tries please post your results Dwight
I updated to 6.6.1 this morning. My 2 HDPVRs appear to have been recognized (with LibreElect 6.6.1 kernel).
I guess I'll see how recordings go ![]()
I updated to 6.6.1 as well and both HD PVRs appear alive and well. I also tried the Digital Devices kernel (actually, I wasn't paying attention and accidentally installed it first) and then installed the LibreELEC 6.6.1 kernel. Both appear to work fine.
Can you use SJQ from within unRAID | wayner | SageTV for unRAID/Docker | 4 | 06-29-2017 12:54 PM |
unRAID DVB 6.3.5 | wayner | SageTV for unRAID/Docker | 5 | 05-31-2017 06:35 AM |
unRAID 6.3 is out | wayner | SageTV for unRAID/Docker | 11 | 02-21-2017 07:32 AM |
unRAID 6.3.0-rc9 | EnterNoEscape | SageTV for unRAID/Docker | 5 | 02-05-2017 07:23 AM |
unRAID | wrems | Hardware Support | 19 | 04-13-2010 02:32 PM |
