SageTV for unRAID/Docker Discussion related to SageTV for unRAID/Docker. Questions, issues, problems, suggestions, etc. relating to SageTV for unRAID/Docker should be posted here. |
Java 8 - No Android / Java 10 - No Schedules Direct - Stuck?
Hello,
I'm stumped... I was running the Java 8 docker on Unraid and when I updated the docker a couple of weeks ago I lost the ability to connect with the Android app (both the old and the new version). I switched to the Java 10 version and everything worked great. Unfortunately I found that the EPG data wasn't updating so after a couple of weeks I got 'No Data" on all channels. To check the Schedules Direct connection, I added a new source, and when it got to the schedule direction step I got a message that it was unable to connect to the schedules direct server. I deleted the sdauth file and re-entered in my username and password, but again for the unable to connect to the schedules direct server. I went to a different unraid server and installed a new docker for Java 10 and got the same schedules direct error, and I installed a new docker for Java 8 and couldn't connect from the android client. So new computer, new dockers, same exact error. Reading the forum, there are statements that schedules direct doesn't work in java 10 only java 8, but since I can't connect to the android client (the only way I use sagetv on my shield) I can't drop back to java 8. There's also a reference to adding some start up commands on the docker to get schedules direct to work on Java 10, but I couldn't find any actual references to that. https://forums.sagetv.com/forums/showthread.php?t=66134 There is also reference to updating the CA certs, but not sure how to do that or if that is part of the docker https://forums.sagetv.com/forums/showthread.php?t=65465 I'm kind of surprised I don't see more people asking about this issue as it seems out of the box I was able to re-create it. Are people using something other than schedules direct nowadays? I'm fine switching that piece of the set up if that's what is required. Edit: Also, I'm wondering if I am just having a network issue in my docker. I switched between host and bridge, but still had the same issue. Not sure what else to check in the docker. Thanks, flips Last edited by Flips; 07-24-2021 at 10:52 AM. |
When I updated the Java 8 Docker I had similar issues. I wound up reverting back to Java 7 and everything started working again. The only downside is that I can't upgrade to the latest 9.2.5 version, so I'm trucking along with v9.2.2 for now.
----- AMD Ryzen 5 3600, B450 m/b, 32Gig, lots of disks, Unraid, 2x HDPVR2 tuners, HDHomeRun Prime, HDHomeRun HDHR4 OTA, Windows Live Tuner, SageTV docker, OpenDCT docker, Win8.1 VM, EventGhost |
You might want to read thru this post: https://forums.sagetv.com/forums/showthread.php?t=66735
I will say that after reading thru that post, I'm still not certain what the "recommended" java version/docker image would be.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, Unraid 6.9.2, sagetvopen-sagetv-server-opendct-java11 Docker Tuners: 2 x SiliconDust HDHomeRun Prime Cable TV Tuners, SiliconDust HDHomeRun CONNECT 4K OTA Tuner Clients: Multiple HD300 Extenders, Multiple Fire TV Stick 4K Max w/MiniClient Miscellaneous: Multiple Sony RM-VLZ620 Universal Remote Controls |
I checked the logs for the other dockers running on latest and I get a similar message about bintray: Code:
*** Running /etc/my_init.d/25-upgrade-gentuner... --2021-07-25 01:57:51-- https://bintray.com/artifact/download/opensagetv/sagetv-plugins/GenericTunerPluginLinux/gentuner-1.0.1.tgz Resolving bintray.com (bintray.com)... 108.168.194.93 Connecting to bintray.com (bintray.com)|108.168.194.93|:443... connected. HTTP request sent, awaiting response... 403 Forbidden 2021-07-25 01:57:51 ERROR 403: Forbidden. |
Right… if you read the thread linked in the post above you would see that Bintray has gone away. Stuckless tried to update the dockers but Java 7 is no longer available and something appears to be broken with the Java 8 docker. It’s a shame because Java 8 is generally the best version to use with Sage these days.
Sage itself seems to work with almost any version of Java, but many of the plugins only work with certain versions.
If you have a backup copy of your files, then you can stop the docker, copy over the files edit the container settings to show Java 7, start it up and see what happens. When I initially had my issues, I tried Java 11 and 16 and both worked but a few things broke in my setup with each version. You might experiment a bit and see what happens. I was lucky that I could just restore my files every time and try a new Java setup until I got things working again.
Oh I see.. yeah unfortunately I don't have that set up, but I should look at that.
Zogg, Tiki, Keith, Thanks for your help! During my last message I was troubleshooting for a couple of hours with different Java versions, etc.. At the very end I logged in to schedules direct to check my username and password was still working, and my account was paid up. When I did that I saw a message that they were current having some server down time... ![]() Where I ended up was updating to Java 16, schedules direct worked, and the android app worked. For me (actually my parents) that is all I needed. They don't use anything outside of the very basics, so we haven't run into anything that's broken yet... Possibly I will get a call in the next couple of days, we'll see.. ![]() Thanks again! flips |
I have not opened SageTV for many months. Just knew it was running in Unraid's Docker since June and haven't looked at it for literally 5 months (summer, studying for new job, etc). Today I logged in and found no channel schedules from Schedules Direct were loading and nothing had recorded since mid-June. Basically nothing would tune, nothing would play, and nothing was on the schedule. When I deleted a tuner to trouble-shoot re-adding it I was getting the error "There was a problem communicating with the Schedules Direct Server" message.
I followed the instructions on this post to update to stuckless-sagetv-sever-java16 : https://forums.sagetv.com/forums/sho...9&postcount=10 All seems good again! I'm posting since it took a good 2 hours of screwing around ![]() ![]()
This space intentionally left blank |
Schedules Direct and Java 10 (not working) | stuckless | SageTV EPG Service | 5 | 04-16-2018 08:34 AM |
SageTV 6 Client problems after Java 7 install, Java 6 uninstall | alisonnic | SageTV Software | 5 | 01-24-2013 02:51 PM |
Java SE7 Favorite limit day problem (vs Java SE6) | voidpt | SageTV Software | 0 | 10-21-2012 12:29 PM |
Tables, Java - Java Not being Called for each TableComponent Cell | stuckless | SageTV Studio | 3 | 04-02-2008 03:03 PM |
Beta V1.2.2 Java java.lang Null Pointer Exception | hamptonhills | SageTV Beta Test Software | 1 | 03-27-2003 12:11 PM |
