Old 08-24-2021, 09:29 AM
jusjoken jusjoken is offline
Travis-CI for OpenSageTV scripts
For developers using the plugin system or other scripts that may run on OpenSageTV account using Travis-CI, I approached the Travis-CI team and they have provided us another 25000 credits (on top of the base 10000 credits they provide for free accounts). We use 10 credits for every minute of script runs so we now have enough credits to run 3000 minutes of scripts.
"We" need to manage this together as if the credits run out (or low) we need to ask for more or these scripts will stop running...for example new plugins or plugin updates will stop being made available to users.
This should keep us going for some time given the low amount of changes to plugins.
K
Old 08-24-2021, 09:49 AM
Old 08-25-2021, 04:36 AM
At some point, you could look into github actions and just move away from Travis. It likely would not be hard to migrate, would just take some time for someone to understand how to run the same commands under the github actions platform.
https://docs.github.com/en/actions
Travis CI Check in GitHub Narflex SageTV Github Development 10 05-05-2020 06:32 PM
Could I pay one of you to write some SJQ scripts for me? FlyingShawn SageTV v7 Customizations 14 01-31-2012 04:09 AM
Scripts: SageTV backup scripts (dailly config, full weekly, full manual) robogeek SageTV Customizations 50 01-24-2012 07:24 AM
/opt/sagetv/scripts references slamduncan SageTV Linux 1 05-12-2007 12:29 PM
init scripts ChePazzo SageTV Linux 0 12-16-2006 12:28 PM
