Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Gemstone for v9
Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 12-22-2021, 10:14 AM
t4runnr t4runnr is offline
Flow list font sizes
Is there a way to adjust the font size of the gemstone flows?
Old 12-23-2021, 06:44 AM
jusjoken jusjoken is offline
The simple answer is no...there is no user interface way of changing the font size used in the flows.
The font size for Flows is hard coded in the STV itself so could only be changed through an STV change using SageTV Studio. If there is a specific flow or more details on what change you want I may be able to guide you to where this change would need to be made but unless you have used studio before it can be daunting.
Adding a user interface to change the flows font is likely not something I would do any time soon as all the flows if I recall are based off a single main font size with a + or - to adjust based on the flow design so it would be doable just may affect other parts of gemstone inadvertently.
K
Old 12-25-2021, 08:56 AM
Thanks for the reply.
Its not a requirement. Just an inquiry.
I never used Studio so I dont even want to mess with something that isn't broken.
Old 12-28-2021, 10:29 PM
cupp cupp is offline
When I upgraded to the latest version I also noticed that the top of each letter is cut off on upcoming and recorded flows in gemstone. I went through every configuration and can not correct the issue. Not sure what caused it.
Amd 780g/athlonII x4 635/3 x 1 tb sata/4 gb ddr2 800/win7 32/sage 9/3xmvp/2xclient/2xhd200/
4xhd300/2xhvr2250/2xhdhrprime
Old 12-29-2021, 06:26 AM
Try renaming the fontcache folder to something else and restart SageTV. Sage will then rebuild the font cache based on the current system you are running.
You can then delete the renamed fontcache as it will no longer be in use.
K
Old 12-31-2021, 10:08 AM
That worked. Thanks so much for all your work helping Sagetv moving forward.
Old List flow from Diamond badreligionhead Gemstone for v9 4 04-13-2017 09:37 PM
Diamond list flow doesnt work. Biggen Diamond 11 03-23-2011 04:44 PM
Diamond Flow lost left/right move thru list Midwestfarmer Diamond 6 03-06-2011 06:37 AM
Menu Font Sizes fidget SageTV Beta Test Software 3 05-21-2010 12:13 PM
Alter font sizes. sfag SageTV Software 1 01-29-2009 08:05 AM
