Audio Sync Issue with just DVDs and DVD files
I have noticed with 2 different audio decoders that the audio is delayed when playing back a DVD on disc or a DVD from file.
I have tried both nvidias audio decoder and ac3filter. Both are set to spdif pass-thru, and the delay happens when using either DD or DTS tracks. The delay seems to be about the same amount with both decoders. I have tried playing with the lip/sync time in the decoders using radlight but that does not seem to affect anything. The audio seems to be behind the video. Now if I play the same movie thru WinDVD5 with passthru it is fine. I tried using Intervideos decoders but they seem to only ouput PCM when not used through WinDVD (note I can get spdif pass thru with WinDVD5, just not with using its decoders in SageTV). Any tricks to fixing this, I have searched the forums and tried a few things but nothing seems to help. It is also very time consuming, playing the video t o a good ref. point test, change a decoder/setting replay the video to the same ref. point, rinse and repeat. |
Ok no one has any suggestions.
Well would using ReClock help my situation? |
I use reclock with ac3filter and Sonic Decoder with no problems.
I believe you should try reclock anyway. |
Well tried ReClock and that seemed to fix my issues
![]() What I find strange is that Reclock does fix it, because the videos with audio delay issues were ones where the audio decoder just did a passthru and reclock confirmed that. So Reclock could not adjust the timing on the spdif data. I guess it can still do tricks with the video side of things. Anyhow it seems to be working now. |
