Old 01-05-2011, 08:42 PM
Brent94Z Brent94Z is offline
Thanks Fuzzy for the shortcut "Recording Schedule" plugin!
Just saw the new plugin show up and it is quite handy
Nice job! Thanks!
Old 01-06-2011, 03:59 AM
Another fancy < 5 line of code plugin from Fuzzy.. I aim low.. ;-)
Old 01-06-2011, 08:07 AM
Hey, even the super simple stuff is appreciated by those who don't have the know how, or time to learn how to do it, so thank you much even for the easy stuff!
Old 01-06-2011, 11:22 AM
pjpjpjpj pjpjpjpj is offline
+1.
Fuzzy, I still say you should have started a new thread about it. I suspect many users don't know it even exists.
(and what happened to the "customization announcements" forum? Maybe Sage needs to make it mandatory that you post an announcement there before they publish a plugin... )
Old 01-06-2011, 11:29 AM
Meh, I can put a thread up... but this one should suffice... ;-)
Old 12-22-2017, 06:39 PM
Scriber Scriber is offline
Hey Fuzzy, tried to install this plugin after a Sage server migration and it throws a resource error - any chance you can fix?
Old 12-27-2017, 08:44 PM
I'll have to figure out what's going wrong (if/when I get a chance to).
Old 10-16-2018, 07:22 PM
bela41 bela41 is offline
Fuzzy, not to hound you about this, but after doing my own migration I noticed the old plugin didn't work. Found this post while searching for a solution. Any chance you figured this out?
HD200, "1080i @ 59.94" and Fuzzy Picture? Savage1701 SageTV Media Extender 10 12-17-2010 09:16 AM
Recording Schedule "Parallel" bigbill SageTV Software 1 11-17-2008 06:22 PM
Recording schedule and "watched" recordings? drewg SageTV Customizations 5 07-08-2008 01:41 PM
Tuner Order on "Recording Schedule" Screen CarlR SageTV Software 2 03-05-2008 02:32 PM
Feature suggestion: "Wishful thinking" columns on Recording Schedule Screen mattchapin SageTV Beta Test Software 9 02-18-2004 04:07 PM
