Old 06-10-2017, 12:26 PM
UgaData's Avatar
UgaData UgaData is offline
External BD/DVD plug-in download failed
I tried to install the external BD plug-in but it failed to download.
I am installing the plug-in on the client PC only. Unless of course it needs to be installed on the Server as well (the server isn't used for viewing anything).
Old 06-16-2017, 07:19 AM
UgaData's Avatar
Fuzzy,
Are you no longer making this plug-in available?
Old 06-21-2017, 01:55 AM
I haven't intentionally removed it. It think dropbox may have changed something in how files are presented, so I'll need to pack them up and put the plugin elsewhere.
Old 08-14-2018, 11:51 AM
dstanley's Avatar
dstanley dstanley is offline
Will this work with the new Sage 9 Clients?
I am also getting the Dropbox location error when trying to install the plugin ...
Dwight
Old 08-15-2018, 10:57 AM
UgaData's Avatar
I expect the plug-in works fine with SageTV9.
Fuzzy just hasn't looked into since the plug-in started having issues with Drop Box. Fuzzy hasn't been around much lately either.
I suspect if anyone has it in a backup from an older install, it could be copied into a new install of Sage.
Old 09-24-2018, 07:37 AM
UgaData's Avatar
in lieu of being able to download this plug-in through Sage, does anyone have the actual zip file they could make available?
I hope asking this isn't a violation of any sorts.
Old 09-25-2018, 10:45 AM
Sorry guys, made some major moves in my life and don't even have a sage server running for the last few months. I think this is the most recent .zip file that was in the dropbox - it should be able to be used in the 'new' github based repository, but I won't have time to get it in there for a while. If someone else would like to, they are more than welcome to.
Old 09-25-2018, 04:15 PM
jusjoken jusjoken is offline
I placed the file onto BinTray and created a SageTV 9 plugin entry for this.
In theory it should now be available under SageTV 9 plugin list for update or install.
k
Old 09-26-2018, 07:18 AM
UgaData's Avatar
Thank You Fuzzy and Jusjoken.
V9 Plugins - Failed Resource download? brandypuff SageTV Github Development 7 07-17-2018 08:51 PM
Jetty download failed, BMT won't install farscapesg1 Batch Metadata Tools 2 11-28-2011 09:50 AM
Attempted download/install of plug-in keeps failing Chriscic Diamond 2 03-21-2011 09:41 AM
Upgrade to 7 - Plug ins from 6 not showing in plug in list personalt SageTV v7 Customizations 1 05-23-2010 11:29 AM
Nielm's External Status Monitor - Download Link? swift_gti SageTV Customizations 2 07-10-2008 10:08 AM
