Old 12-16-2017, 06:27 AM
rickgillyon's Avatar
Schedules Direct Have Blown Away UK Lineups
See here:
http://forums.schedulesdirect.org/vi...hp?f=15&t=2966
Your *UK* lineups (Freeview, Cable, Sky, Freesat) have all been deleted by SD. You'll need to set them up again.
There goes half of my day...
Old 12-17-2017, 12:55 PM
starfire starfire is offline
Yes very annoying, now have to try and remember how I set it all up in the first place
Old 12-17-2017, 01:05 PM
I used the Import/Export plugin to export my lineups, imported them into Excel so I could sort them, then used them as reference for the new lineups. Saved some time...
TBF we seem to have a full 14 days or more of listings now, so a big improvement.
Old 12-17-2017, 02:06 PM
Just did it manually, printed out the .frq for the physical channel numbers and went through all channels we tend to watch and remapped.
Pity Sage doesn't use logical channel numbers from Freeview signal then it would be OK.
Old 12-18-2017, 02:12 PM
deanm deanm is offline
Just what I need a week before Xmas.
Only have tonight to sort it out.
Dean
Darkside: DVB-C x4 DVB-T2 x2 HD-300 x4
Lightside: DVB-C x2 DVB-T2 x4 HD-300 x3
Schedules Direct - How Far Out Does it Get? mike1961 SageTV EPG Service 7 06-17-2017 11:31 AM
schedules direct changeover Galaxysurfer SageTV EPG Service 2 06-14-2017 08:57 PM
Schedules Direct vs Guide DynamoBen SageTV EPG Service 1 06-12-2017 08:34 AM
Using Schedules Direct in UK jamesdisco SageTV United Kingdom 28 02-06-2017 11:54 AM
