Old 03-06-2007, 10:44 PM
rnewman rnewman is offline
ADDING CHANNEL TO XMLTV Import Tool
Ok!
I was successful in getting both XMLTV.exe and StephaneM's
XMLTV Import Tool working with my cable tv channel lineup.
Now I want to add hd channel for another tuner
I ran XMLTV with "over the air" to get needed info.
for one analog channel XMLTV came up with:
<channel id="I11484.labs.zap2it.com">
<display-name>2 WGRZ</display-name>
<display-name>2 WGRZ PC:14225</display-name>
<display-name>2</display-name>
<display-name>2 WGRZ fcc</display-name>
<display-name>WGRZ</display-name>
<display-name>NBC Affiliate</display-name>
</channel>
and for the hd channel:
<channel id="I31507.labs.zap2it.com">
<display-name>2 WGRZDT</display-name>
<display-name>2 WGRZDT PC:14225</display-name>
<display-name>33 WGRZDT fcc</display-name>
<display-name>WGRZDT</display-name>
<display-name>WGRZDT (WGRZ-DT)</display-name>
</channel>
I see two different channel ID
I editing epg.xml to add, no good
I added channel in import tool using wgrzdt's info
and it added to program listing but displayed "NO DATA"
What did I do wrong?
Ray
Old 03-06-2007, 11:36 PM
If I run:
xmltv.exe tv_grab_na_dd --configure --config-file cable.conf
xmltv.exe tv_grab_na_dd --configure --config-file ota.conf
xmltv.exe tv_grab_na_dd --config-file cable.conf --output cable.xml
xmltv.exe tv_grab_na_dd --config-file ota.conf --output ota.xml
xmltv.exe tv_cat ota.xml cable.xml >epg.xml
I get a epg.xml with no duplicates
But how do I get xmltv importing tool to run:
Ray
Old 03-09-2007, 05:00 PM
Finally got everything working.
XMLTV Import Tool works GREAT
Using clone channels made adding HD cable and OTA
channel additions possible.
Great software.
Ray
My EPG Experience... Azam SageTV EPG Service 6 04-10-2007 10:21 AM
Channel change fails ~50% of the time, first digit doesn't work compunerd632 Hardware Support 7 09-30-2006 11:43 AM
New source for XMLTV Guide Data antplugger SageTV EPG Service 1 03-17-2006 08:08 AM
Choppy Playback with Import STV's??? RedCoat999 SageTV Customizations 3 12-09-2004 10:28 PM
Subscription Options ? LCH SageTV EPG Service 72 07-09-2003 05:38 AM
