Change point of thumbnail generation?
Hi,
I live in Germany, where shows often do not begin exactly on time. I have a default padding of +/- 5 minutes (Thanks to the creator of the default padding STVi). If a show begins at 10pm, I think that SageTV generates the thumbnail at exactly 10pm. This way my thumbnails often show commercials. Is there any way or properties setting that can change the position of the thumbnail generation? Something like "thumbnail_padding=120" to create the thumbnail at 10:02pm? I hope I made myself clear. Thanks, Oliver
Oliver Kötter ------------ Check this thread for importing German TV Data into SageTV Using SageTV 7.1.9, Java 1.6.0_24 Win7 Home Premium on an Asus M4N78-AM Mainboard, AMD Athlon II X2 215, 4 GB RAM, 500 GB HDD, 2xTechnoTrend S-2400 as Network Encoder (LM DVB Smart Recorder), ATI Radeon HD 3450 with analog TV-Out on good old CRT TV (100Hz) My avatar shows the world's best composer!!! |
try video_thumbnail_extraction_time_offset_sec Dirk |
Coooooooool... thanks a lot!
You can also use my VideoEdit plugin and choose any position in the video to generate the thumbnail from. It launches the SageTV Transcoder and tells it where to generate the thumbnail. This doesn't change the property to that position so it has to be done for each video.
Any way to exetuner to change channels on a network encoder? | olyar15 | Hardware Support | 13 | 06-24-2009 12:33 AM |
USB-UIRT & DCT6412 channel change problem | johnnyspo | Hardware Support | 4 | 01-18-2007 09:27 AM |
Cannot change Server channel while Client is viewing TV | smokescreen | SageTV Software | 3 | 01-06-2007 04:47 PM |
how to change a Widget's property in an STVi | Tiki | SageTV Studio | 5 | 01-04-2007 12:29 AM |
Channel lineup change question.. | Stuntman | SageTV EPG Service | 1 | 08-31-2006 03:33 PM |
