Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV. |
Gemstone 1.402 released
To ensure users get the most from Gemstone I have updated gemstone 1 with the following....
Gemstone 1.402 release - minor fix
This contains a fix for when there is no default epg/zip_code set from an old sagetv EPG install.
If your weather is configured and working already then no rush to upgrade unless you just want to stay current. k |
Awesome! I will give it a try and see how it goes. Do I just run the update on the server? What about clients that are currently connected when I run the upgrade - do they have to have the UI reset?
A windows client needs to be updated separately k |
I installed it but it still appears that the focus returns to the first item in a list of shows when I stop a show. This is both on an HD200 extender and Placeshifter.
The Plugin manager reports version 4.0402. Last modified on 10/2/2017. SageTV version is 9.1.7.581 on unRAID. Current STV File Gemstone.xml (Version 1.0401, Name: Gemstone). Java is 1.8.0-111. OS is Linux 4.9.8-unRAID
I have the identical setup as you and the focus issue has been resolved for me. k |
That's what I see. I definitely restarted the docker but I will do it again just to make sure.
More details and a log with debug turned on in gemstone utilities will help. k |
It says TV Test Flow - this is a TV flow with banners on the left. Maybe I have to recreate the flow?
Here is what it shows in options: Name: TV Test Flow Type: Sage Flow Level Overrides [not selected] View: Base - TV
What info options do you use...i use the default panel on the right with a poster. Also, lets make sure its the same issue...it does not really return to the top of the list...the sage flow list on the left is on the series you just played but the poster on the info panel and title on the info panel are for the first item in the tv list...is this what you are seeing? I also use play options which lets me press play a second time and play the next unwatched episode...is that how you use yours? The core issue i resolved was related to the play command not setting a value correctly before play..so it may be that you do not use play options and i missed an area the setting is still wrong. k |
Here is the issue as I see it:
When you are in a long list of episodes for a TV show - let's say you have 5 or 6 pages and you can view 10 episodes per page. Let's say you page down and play episode number 33 - by selecting the episode and then selecting Watch Now. When that episode ends and SageTV takes you back to the list of episodes it returns to the top - the first episode on the first page. It should return you back to where you were in the list - the 33rd episode in this instance. My info options appear to be a thumbnail or poster on the right along with the shows metadata - it appers to be Info Style- Side Poster.
Weather Issue 1.0402
I'm having a problem where I can't change my location.
It is currently 90210. If I try to change it nothing happens. The properties file does however show my correct zipcode epg\zip_code = 10990. Compared WU website and data being displayed in Sage is from 90210, not 10990.
SageTV User Since 2009 Server Hardware: AMD FX6100, 6 Cores, 3.3GHz, 8GB RAM, TA970XE MB, 3TB HD, HVR-2250, HD-PVR, nVidia 9600GT 512MB Server Software: SageTV 9, Windows 10 64bit, EventGhost Client Hardware: HD200 x2, INT-422-3 & WR7 Remote Service Provider: Cablevision (QAM to 2250, SamsungBox to HDPVR) |
Use Clear Location Then select location and enter the zip what happens at this point in the process? As this should now show the new weather for your entered zip. I just tried your zip and it worked fine for me. If you still have issues please advise if you are trying on Yahoo or Wunderground. PS: the epg/zip_code entry is not used any longer by gemstone. k Last edited by jusjoken; 10-03-2017 at 11:44 AM. |
k |
Gemstone 1.0403 released
This contains a minor fix where the EpisodeSimpleList setting in TV Flows was not saving and returning to the last focused item after playing.
k |
Tried WU and Yahoo - no change. Got it to accept my zipcode by switching to SageTV7 UI, making the change there, then switching back to Gemstone UI. Now it's using my zip.
I have the latest release up and running I fix the weather but then it defaults back to 90210 Beverly Hills Ca. This happens on my Windows Clients all others are OK. Android clients are all ok.
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 10-03-2017 at 02:45 PM. |
And what type of client are you using. k |
k |
BMT 4.9.21 Released | stuckless | Batch Metadata Tools | 4 | 07-06-2011 10:25 PM |
314 Is released | stuckless | Phoenix | 11 | 06-18-2011 10:13 AM |
BMT 4.9.8 Released (No Fixes) | stuckless | Batch Metadata Tools | 6 | 01-28-2011 11:53 AM |
SageTV V5.0.4 Released | Narflex | SageTV Software | 30 | 06-25-2006 03:14 PM |
SageTV 5.0.2 Released | Narflex | SageTV Software | 37 | 05-25-2006 02:28 PM |
