Go Back   SageTV Community > SageTV Development and Customizations > SageTV v9 Customizations > Gemstone for v9
Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV.
Old 10-20-2018, 02:20 PM
issue with gemstone
while using gemstone something has corrupted so that when i click on a show it doesn't display ability to delete file at end of watching it. no options for deleting appear at all. sometimes it will display delete all . i was able to fix temporarily be doing a repair install. so not sure what happened. functions seem to return to normal by uninstalling gemstone & returning to default gui theme.
i was running last version of 9.09 & now installed 9.10.
Old 10-20-2018, 05:36 PM
jusjoken jusjoken is offline
Can you post the sage and gemstone logs from right after the issue presents itself?
Also, can you describe the steps to recreate the issue including what flow or screen you are on.
k
Old 10-24-2018, 12:48 AM
okay after multiple reinstalls I finally got the setup working properly. It seems to be just majorly corrupted setup. Didn't help when I moved to newer version of software & upgraded java. Thanks for the prompt response.
What is Gemstone? xjim1 Gemstone for v9 2 07-16-2017 07:47 PM
Gemstone 1 for v9 jusjoken Gemstone for v9 18 01-07-2017 10:37 PM
Gemstone and V9 BigSwifty Gemstone for v7 1 02-27-2016 02:06 PM
Gemstone FAQ jusjoken Gemstone for v7 9 05-24-2013 12:57 PM
Gemstone for Movies Only? tmiranda Gemstone for v7 22 12-05-2012 10:38 AM
