Gemstone for v9 This forum is for discussing the user-created Gemstone custom interface for SageTV. |
Thumbnails in Gemstone Flows
For some reason the thumbnails in Gemstone Flows are horribly pixelated. The default Sage views are fine just the Gemstone flows.
Typically I use the IMDB search to grab metadata and the picture that shows up in the flows. What am I missing or have wrong. In the past, I have had Gemstone and the pics were fine.
"Unencumbered by the thought process" The only constant in the Universe is change. |
I always use BMT. Make sure its installed and when Phoenix core grabs the Metadata you can use BMT to verify and edit it.
k |
I have BMT installed and the images look bad in BMT as well.
I can re-choose and make default each thumbnail/poster and it looks a little better in BMT but the results don't carry over to the Gemstone Flows.
Solved - Not Solved?
OK, So I recently nuked my Sage Client install. Just the SageTV install - not the OS. I also re-did the server install but that doesn't effect this ????
After the re-install of SageTV client and re-installing Gemstone, BMT, CMT and whtever else - the Thumbnails, posters, and fanart look many times better. Some may tend to be blurry but they are not pixelated like before. F.W.I.W. Even the default main screen when Sage is opened with Gemstone looks better. The center light burst? looks smooth instead of square, jaggies (pixelated).
Delete flows | crawfofd | Gemstone for v9 | 4 | 06-02-2017 03:53 AM |
Gemstone flows and cached cover art | badreligionhead | Gemstone for v9 | 8 | 04-22-2017 08:47 PM |
More than 11 Flows? | silkshadow | Gemstone for v7 | 7 | 10-27-2012 09:41 AM |
Grouping in flows | Dargason | Gemstone for v7 | 1 | 09-11-2012 02:26 PM |
I don't see anything under flows | wayner | Gemstone for v7 | 3 | 09-07-2012 10:15 PM |
