Old 03-11-2020, 03:29 PM
PeteCress's Avatar
HD-200 Remote: Hoqvto open?
I am trying to crack the case on my HD-200 remote so I can clean the key contacts.
But no joy so far.
Does anybody know the trick?
Program Source: OTA antenna
Old 03-11-2020, 03:41 PM
This post might help: https://forums.sagetv.com/forums/showthread.php?t=65471
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Old 03-18-2020, 01:11 PM
PeteCress's Avatar
Originally Posted by KeithAbbott View Post
By everything I have read so far, that thread should have done the trick, but no joy yet.
I did find the screw down at the base of the control under the decal.
But somebody else in the thread referred to three (3) screws... and, for the life of me, I cannot find the other two.... Replied to his post, but did not hear anything back.
Seems pretty clear that *something* is still holding the 2 halves together.... but what and where?
Old 03-18-2020, 03:34 PM
wnjj wnjj is offline
Maybe it was a typo. One of his other pictures shows only 2 screws sitting on laptop.
There's one behind the label and one in the battery compartment. I don't see where any other would be.
Old 03-18-2020, 03:49 PM
Another post that might help: https://forums.sagetv.com/forums/showthread.php?t=61979
Old 03-18-2020, 03:54 PM
PeteCress's Avatar
Yeah, I removed the battery compartment screw too - even though it did not look like it was holding the case halves together.
But the thing still doesn't want to come apart and I fear unleashing my inner Magilla-The-Gorilla on it.
Old 03-18-2020, 04:01 PM
KryptoNyte's Avatar
Hey, Pete. If you totally ruin that thing trying to pull it apart to clean it, please document the process with some photos and I'll send you an HD200 remote that I have somewhere in storage. It's used, but I recall it working fine when I decommissioned it.
Old 03-18-2020, 04:06 PM
Someone in that post Keith just added said they had to pry really hard.
Also thinking about that other guy’s comment: he said it’s where his 3 were located. I’d bet he was referring to his 3 remotes, not screws.
So I’m saying it’s one screw and a lot of prying.
Old 03-27-2020, 12:06 PM
PeteCress's Avatar
That's what worked.
I took a bunch of pix, but the forum won't let me upload them.
Will email a .zip file if anybody wants it.
Have you a better idea? I'm open! billkalicious SageTV Software 11 04-03-2009 02:10 PM
Open TV EPG B52 SageTV United Kingdom 0 09-12-2008 04:38 AM
Open to second display jake_friz SageTV Software 5 07-07-2004 03:41 AM
Can't open setup nox71 SageTV Recorder Software 1 01-27-2004 06:01 PM
Various open bugs... Boxster_T SageTV Beta Test Software 12 07-28-2003 12:58 PM
