Old 03-18-2020, 11:05 AM
Steve52 Steve52 is offline
HD-300 Settings
Can someone please tell my how you get into the setup on the HD-300. I am going to need to change the IP address on my extenders soon. When I unplug the HD-300 and then plug it in again, it waits about 15 minutes, and then just comes back up with the normal interface ( the standard one). It doesn’t startup in the setting menu. It has been a long time since I have had to change anything and I don’t remember how to get into the settings.
Central Sage Server Win 10 64 Bit, Two HD200, Three HD300, & One PC Client 21 TB storage. SageTv 64 Bit
Old 03-18-2020, 12:12 PM
When I power-on my HD300, it comes to a screen that has an option to "Stop Auto-connect". Press the ENTER key on the remote, and it should take you to the standalone HD300 main menu. From there you select Settings, then Network.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Old 03-18-2020, 12:58 PM
When I use the power button on my remote to turn off the HD-300 and then use the on power button the sage home screen comes up, and I don’t get that auto connect message. Maybe I will have to shut sage down at the server and then restart sage server, and possibly get the auto connect message at that point. I can’t shut sage down right now to see, but when I can I will try that.
Old 03-18-2020, 03:35 PM
wnjj wnjj is offline
Can you just unplug the ethernet cable before powering up?
Old 03-18-2020, 03:59 PM
I second the strategy of powering up without an ethernet cable. I have to do that occasionally on my extenders.
Old 03-18-2020, 04:34 PM
On the removing the Ethernet cable method. Are you disconnecting the power cable and removing the cable or are you just using the remote off button removing the cable and then using the remote power button to turn back on?
Old 03-18-2020, 05:29 PM
Remove the ethernet cable and then remove the power cable. Keep the ethernet cable out until it boots up to the Settings screen. Then you should be good.
Edit - corrected the above sentence
Old 03-19-2020, 02:20 PM
Yes. That worked.
1) Unplug Ethernet cable
2) Unplug Power cable
3) Wait a few seconds and plug power cable back in.
4) Took my HD-300 about 2 minutes to boot back up
5) Choose not to auto connect to server
At this point you can get into the HD-300 setup options.
What settings with HD-PVR for PC? SageGk SageTV Software 3 01-19-2009 12:55 PM
HD-100 Blu-Ray Rip to MKV Settings skyeclad SageTV Media Extender 15 01-07-2009 10:10 AM
HD-PVR settings SageGk Hardware Support 5 12-22-2008 08:47 AM
HD-PVR - Where are all the settings? CanadianEh Hardware Support 1 06-09-2008 05:10 AM
DVB-S LNB Settings solomonsok Hardware Support 1 10-26-2007 03:09 PM
