Old 04-06-2020, 10:03 PM
jwilson56 jwilson56 is offline
HD-200 STV?
I went from using the PC as the main setup in my living room to a HD200. There is no menu option for SEARCH and would like to get that back.
Anyway to get the SEARCH function on my extender?
Thanks for any help
Old 04-07-2020, 10:33 AM
This shouldn't have anything to do with extender vs PC this is to do with the UI that you are using. Are you using a different UI on the extender? You should be able to export the UI config from your PC and then import it on the extender. At least you can do that from Gemstone which is what I have used as my UI. You might also be able to go back to the default UI by deleting the properties file from the SageTV/clients folder. Each extender should have a properties file that is the MAC ID of the extender. Try deleting this (or renaming it to 12345.properties.old) and you should go back to the default.
