Old 07-26-2020, 09:10 AM
graywolf's Avatar
graywolf graywolf is offline
HD300 Firmware update?
Started getting:
A newr firmware version is available for this device of:
<html>
It is HIGHLY recommended that you perform this update.
Do you want to update now?
(This process may take a few minutes)
When I check, It is currently 20101007-0
Not sure why getting the firmware update message all of a sudden.
Where can I get the current firmware and how to load it?
Tried the Update Firmware and it is failing.
Old 07-26-2020, 09:20 AM
egeller egeller is offline
Originally Posted by graywolf View Post
Started getting:
[CODE]A newr firmware version is available for this device of:
<html>
You are not alone. I run 2 SageTV servers. When I switched between them this morning I saw the same message on my HD300. For now I will resist the urge to update until someone can explain what is going on.
SageTV Extender:3x HD200 1x HD300
Sage TV: 9.2.1, Standard STVi, Comskip Playback, Web Interface, 24 Hour Clock, SRE, YouTube2015, Playon
All in lovely Drexel Hill, PA
Old 07-26-2020, 09:53 AM
wnjj wnjj is offline
The latest firmware is 20110506-0. I’m not sure why it just now started asking but likely due to whatever Narflex did with the server the other day. That also could be why it fails to download.
Windows Installer
Old 07-26-2020, 10:06 AM
tvmaster2's Avatar
yup, me too. HD300 wants me to update firmware. Bizarre.
Old 07-26-2020, 02:24 PM
Forgot to mention that my HD300 is running that latest firmware already and I don’t get an update message.
Windows Installer
Old 07-26-2020, 06:49 PM
tvmaster2's Avatar
If the latest firmware is 20110506, and mine is reporting 20101007, are the updates still on the Sage servers, or do we have to update via USB or some other method now? Anyone do an update in the last few years?
Old 07-26-2020, 08:06 PM
LHuisingh LHuisingh is offline
I'm in the same boat on both my HD300 units. I did just perform an update a few weeks ago and it seems like the version number went backwards.
Old 07-27-2020, 01:45 AM
Ok so it seems that 20101007 may be the last released version and what I have is the latest beta version. Firmware discussion is here: https://forums.sagetv.com/forums/sho...812#post497812
However when I click on any links to firmware locations the result is a “forbidden” error. Something is off since Narflex moved the DNS stuff the other day.
Windows Installer
Old 07-27-2020, 08:13 AM
tvmaster2's Avatar
Started getting:
<html>
ALL three of my HD300’s are now having real problems just connnecting to the network, returning bogus IP address info and just acting sluggishly.
Are you seeing any of these signs?
For example; if I change the IP address setting, my router doesn’t see the change anymore, and just displays the old setting.
Old 07-27-2020, 04:39 PM
graywolf's Avatar
Checked and my hd300 settings haven’t changed
I have static IP for all my SageTV hardware (server, hd200/hd300, etc)
Old 07-27-2020, 04:58 PM
tvmaster2's Avatar
ok, thanks. That’s what I have as well. But when I tried to change them to DHCP, the HD300’s lost connection, and now won’t reconnect.
Old 07-27-2020, 07:22 PM
trk2 trk2 is offline
Just an FYI for anyone looking at upgrading the HD300 firmware. DTS-MA is broken in beta firmwares 20110217-2 and later. If you are bitstreaming DTS-MA media you will get audio drop outs or no audio. FLAC is broken in the latest official release. Playing FLAC files will cause a no audio requiring a HD300 reboot to correct.
The alternative is to use beta firmware 20110124-2 which works with FLAC and DTS-MA. To install this firmware requires a manual install. The HD300 user manual explains how to do a manual firmware install.
Old 07-27-2020, 09:52 PM
tvmaster2's Avatar
ah, will 20110124-2 work for all current audio formats? Any other reasons to install it or leave best alone?
Old 07-27-2020, 10:03 PM
Yes, it should work for all the advertised audio formats including hd audio. If you're not having audio problems, than I would leave it alone. If you start having audio problems, you can always give 20110124-2 a try.
Old 07-28-2020, 07:28 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
Dumb question: I have used our HD300 as a SageTV Client continually for over ten years and I don't remember how I set it up. How does one go about viewing the System data -- specifically the Firmware version?
Old 07-28-2020, 09:08 AM
tvmaster2's Avatar
Boot page. Settings.
Old 07-28-2020, 09:32 AM
Setup > System Information (within SageTV main screen) also has firmware version information.
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Old 07-28-2020, 10:43 AM
RonBoyd's Avatar
Okay, that was my fault. <chuckle> How does one get to the "Boot" page?
I had looked in the SageTV display and found reference to "Firmware Version" 20101007-1. I assumed it was the HD300 data but it wasn't identified as that. In any event, I didn't know where to go from there.
USB firmware update for HD300 Pelicanjoe SageTV Media Extender 1 05-09-2015 05:39 PM
urgent; HD300 hung during firmware update!!! carlgar SageTV HD Theater - Media Player 5 05-29-2011 06:05 PM
HD300 won't update to latest Beta firmware mgpaulus SageTV Media Extender 6 05-13-2011 10:14 PM
Firmware update gone bad! blair_42 SageTV Media Extender 9 01-27-2010 06:40 AM
