Old 07-26-2020, 04:37 PM
HD300 Versions 1.0 & 1.1
I had to remove the boards from a few of my HD300s recently, and was surprised to find out that there were at least two versions of the circuit boards inside the HD300s! Check out the attached photo, version 1.0 is on the left and version 1.1 is on the right. The obvious difference is the orientation of the heatsink, but there are less obvious differences also.
I wonder if the different hardware versions are functionally identical?
Server: MSI Z270 SLI Plus ATX Motherboard, Intel i7-7700T CPU, 32GB Memory, unRAID 6.8.3, SageTV & OpenDCT Dockers
Old 07-27-2020, 08:29 AM
RonBoyd's Avatar
RonBoyd RonBoyd is offline
Are they labeled differently on the exterior of the case?
(Asking mainly to subscribe to this thread but do want to know.)
Old 07-27-2020, 08:44 AM
Not that I've been able to see, from the exterior they look identical. You can see the version numbers silk-screened on the bottom of the circuit boards.
JRE Versions? drewg SageTV Linux 14 01-19-2009 10:37 AM
Old versions of Java msmith8228 SageTV Software 1 07-25-2007 03:00 PM
What versions of Linux can be used? InTheFlow SageTV Linux 8 05-16-2007 06:56 PM
MVP Firmware Versions mdnttoker SageTV Media Extender 10 10-23-2006 05:31 PM
Old versions Ja'Man SageTV Software 7 12-03-2005 02:57 PM
