Old 08-06-2020, 07:46 PM
tvmaster2's Avatar
Hauppauge remote turning on BOTH SageTV software AND HD300 - help
I frequently watch SageTV via the Sage server software, on my server, and it's controlled by my Hauppauge 45 key remote.
Problem: that remote is sending at least the same on/off power toggle commands to BOTH my HD300 (which is nearby) AND the SageTV server software on my PC server.
Is there a way to change the power toggle command for the software side of things (since I know I can't reprogram the media extender box) so it gets a different on/off command than does the HD300?
Does this make sense - it's been a long day.
I'm setting up a Logitech Harmony remote, and need seperate commands for Devices and Activities.
thanks
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson
Old 08-06-2020, 08:06 PM
trk2 trk2 is online now
Yes, the HD300 has discrete power on / off commands but I know nothing about the hauppauge remote. I can suggest that if you run into a problem and the individual power commands are not available, the home command can be used instead to turn on hd300 from standby mode.
Old 08-06-2020, 09:04 PM
JustFred JustFred is offline
Have a look at the SageTv manual. The sections under Commands Settings might help with your issue.
Old 08-06-2020, 09:08 PM
tvmaster2's Avatar
One of the benefits of the Logitech Harmony database is all these devices have been pre-programmed, and are mostly correct. Thanks, Ill investigate the home command.
Old 08-06-2020, 09:09 PM
tvmaster2's Avatar
That was my next move, when tomorrow begins
Old 08-07-2020, 09:47 AM
tvmaster2's Avatar
Okay, it is now tomorrow, and my mind is fresh...
The manual lists CTRL+Z as power.
The Hauppauge 45 key remote is mapped the same way, as can be found in 'Detailed Setup/Commands/Show SageTV Commands linked to Infrared/Keystroke'
If I change the CTRL+Z command to something else, say CTRL+B for the Hauppauge 45 key remote, will the HD300 still respond to CTRL+Z?
That would be the goal, to have two different power toggle commands, one for each remote/device ( the HD300 and SageTV server software)
But then, since the Harmony library of remote codes INCLUDES the pre-set CTRL+Z as the Hauppauge power toggle, I would have to go into the Harmony settings and change it to reflect the new command (CTRL+B)?
Make sense?
Old 08-08-2020, 04:57 PM
makes sense, but you may need to find the appropriate IR codes for an IR based keyboard so you can actually send CTRL+Z.
Microsoft made an old Media Center edition IR keyboard that came with a dual IR emitter, so you might be able to find the IR codes for that.
Turning TV on with SageTV remote tonysathre Hardware Support 3 06-24-2011 07:58 PM
Other software for Hauppauge remote Banacek Hardware Support 20 10-29-2010 01:02 AM
HD300 turning off automatically? Brent94Z SageTV Media Extender 14 10-11-2010 04:23 PM
Hauppauge IR remote software bclenney Hardware Support 1 12-28-2009 08:57 PM
Do i have to install hauppauge software to work with sageTv? getstarted Hardware Support 1 08-22-2008 05:32 PM
